Shifting to second grinds a little, shifting very slowly is better though |
Joe Bob |
Sep 19 2005, 07:53 PM
Well...I'm done..... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
olav |
Sep 19 2005, 07:55 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Ok Doug. I'll call on you for details . I agree I'm going in for leaks so at least I can freshen up the 1st and 2nd synchros and learn something. Two hours to yank is not bad. I already have the muffer off anyway. |
tracks914 |
Sep 19 2005, 08:15 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Car on the jacks,muffler off already.... CV's, starter, 3 other engine/tranny bolts and the rear mounting bolts......less than an hour you will have it on the bench.
olav |
Sep 19 2005, 08:22 PM
Thanks for the suggestion. I bought them pliers. Does anyone have a gear pulling tool I can borrow? Thanks! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) So, since I have my car up and muffler off and annoying seeping leaks that need to be fixed I thought since I'm in there I might as well freshen up the 1st and 2nd synchros. I have spend a good many hours adjusting the shift linkage etc but couldn't dial out the grind. Gear oil is pretty new and is Swepco. I'll change that too so it's new. I'm getting the gasket set to replace the older seals too. I'll be using Jame's article and Bondo's classic thread as guides. I'll be starting next weekend. Any other tools I neeed? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Bleyseng |
Sep 19 2005, 08:25 PM
that deep 32mm socket to pull off the 1st gear assembly
tracks914 |
Sep 19 2005, 08:54 PM
And an electric impact wrench to get it off! |
bondo |
Sep 19 2005, 09:26 PM
Big ass crescent wrench, brass hammer, brass monkey, intergalactic, sabotage! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
olav |
Sep 20 2005, 09:15 AM
Check, check, got a monkey puller, on order, ditto... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
olav |
Oct 10 2005, 08:41 AM
Ok, just to follow up.
I've finished with the tranny fixes. Last Friday I pulled the tranny. Saturday I put in fresh 1st and 2nd gear synchros as they were getting tired. The second gear synchro was causing the grinding as it has no tension left in it and I replaced the 1st gear synchro since it gets used the most and only a bit of it gets hit so out it came for good measure. It was showing wear too. All the gears and dogs teeth look fine so I fixed the issue before any expensive damage was done. Also, there were NO gaskets on the intermediate plate, no shims either, just white goop (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) in place of where gaskets should be. That was the reason I had a tranny oil weeping problem. Put in gaskets from the kit and the middle sized shim on the case side. That should to the trick. Also replace speedo angle drive because it was leaking too, POS! Also, the O-ring. Replaced input shaft seal too as a precaution, the old one was kind a hard and inflexible. Put all together and dumped in some fresh tranny fluid, looks a lot nicer than the olden stuff, and put it back in the car Saturday night. Didn't take to long and my car is back up and running with no leaks in the tranny dept and shifts awesomely now. I got to regrease everything associated with tranny pulling like the shift linkage and throttle pully. Also, repacked my CV's with fresh grease and slapped on some new gaskets. Everything looks pretty now down there. Thanks for all the tips and ideas!! Attached image(s) |
Aaron Cox |
Oct 10 2005, 08:46 AM
ummm... does it whine now? there is a good chance your pinion depth is off (guessing at shims/gaskets)
olav |
Oct 10 2005, 08:49 AM
Nope, no whining at all. No leaks and quiet as a mouse. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:34 AM |
