QUOTE (jkeyzer @ Sep 19 2005, 01:53 PM) |
Since the tranny has leaks, does it still have fluid? When was it last changed? Clutch adjustment is a good idea. If you are at a stop and you push in the clutch, wait a few seconds, and then try to shift in reverse, does it grind? |
QUOTE ("Z" @ Sep 19 2005, 02:07 PM) |
Deal with the fluid first, then complain..... |
QUOTE (tracks914 @ Sep 19 2005, 06:14 PM) |
Ps if you're going to do it yourself you will need a good set of snap ring pliers. |
QUOTE (Brando @ Sep 19 2005, 03:18 PM) |
I have a better idea: Ease it into 2nd/3rd when shifting and stop trying to drive it like a racecar! Leaks first... then synchros later |
QUOTE (Lawrence @ Sep 19 2005, 04:08 PM) |
I agree with checking adjustment and fluid levels first. If you do decide to replace the synchro, I'd pull the transmission first. Including the jacking & muffler removal, the tranny can be pulled in less than two hours. Since you'd have to jack the car up and remove the muffler, anyways, I'd just remove the gearbox. I'd much rather work on the gearbox on a workbench, rather than on my back under the car. Good luck, Rusty |
QUOTE (d7n7master @ Sep 19 2005, 04:31 PM) |
If I may suggest; If you haven't replaced ALL of the shift bushings or know that the po has replaced them recently... - there's nothing that U can adjust will be consistant. 2 much "slop" Start with new bushings installed using new set screws. Then adjust your linkage. I like to start adjusting the linkage with the tranny in 2nd. Try it. Worked 4 me; Good Luck |
QUOTE ("Z" @ Sep 19 2005, 05:46 PM) |
It's not just the level...it's the age and quality of the stuff....Swepco is da bomb.... |
QUOTE (tracks914 @ Sep 19 2005, 05:14 PM) |
I just did mine this year. Take off the exhaust, leave the engine blocked up and just pull the tranny. It's easy and in less than 2 hours you have the whole tranny on the bench. The tranny was light enough that I just "bench pressed" it back into place when I reinstalled it. Make sure its a large enough and clean bench. Take apart the tranny piece by piece (Haynes manual helps a bit) and change all you seals and gaskets at the same time. Don't try fixing leaks now then take it apart later for the syncros. Note - depending on how many mile/year you drive, you may get away with just flipping over the old syncro instead of buying new ones. I bought 2 new ones but flipped 3rd one over as the factory manual suggests. Email me if you want more details. It was a bit un-nerving at first taking it all apart but soon you realize it can only go back together one way. Ps if you're going to do it yourself you will need a good set of snap ring pliers. |
QUOTE (bondo @ Sep 19 2005, 05:17 PM) | ||
These work VERY well for this job: External snap ring pliers I broke several "normal sized" ones before getting these, and it's like night and day. |
QUOTE (Bleyseng @ Sep 19 2005, 06:25 PM) |
that deep 32mm socket to pull off the 1st gear assembly |
QUOTE (bondo @ Sep 19 2005, 07:26 PM) |
Big ass crescent wrench, brass hammer, brass monkey, intergalactic, sabotage! |
QUOTE (Aaron Cox @ Oct 10 2005, 06:46 AM) |
ummm... does it whine now? there is a good chance your pinion depth is off (guessing at shims/gaskets) |
