3.0(six) install, any pre-installation maintance |
pete-stevers |
Sep 19 2005, 02:10 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
gettin the stuff togather for the winter project....just wondering is there any special stuff that should be done to the motor before installing??? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
goose2 |
Sep 19 2005, 02:34 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
I'm getting a 3.0 ready to install also, so I'll be watching this thread. My plan is to :
1. Upgrade the timing chain ramps and tensioners (not sure which ones yet). 2. Take a close look at chains, sprockets, etc. while covers are off. 3. Pull valve covers and check for broken studs....adjust valves. 4. Remove FI and replace hoses and intake boots. 5. Remove shrouds and clean cooling fins and block. 6. Get alternator rebuilt and replace belt. 7. Get oil cooler tanked and cleaned after the welding on the 90 degree pipe. 8. Repaint shrouding and detail everything. 9. Replace exhaust studs. 10. Modify turbo valve covers for clearance. While in the process of all the above, I'll check all connectors and fasteners and replace as necessary. I'm probably missing something important...it will be interesting to see what others come up with. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
GeorgeRud |
Sep 19 2005, 10:17 PM
Adjust the valves and then recheck them! It will never be that easy again.
Check and recheck your alternator and connections. |
Root_Werks |
Sep 20 2005, 07:49 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Get your oiler cooler mods done ahead of time. Randy, don't use the oil cooler from the 2.4. It is a small inlet, go with the big inlet cooler from the 3.0.
Yeah, adjust the valves before the engine is installed and if you have turbo valve covers, get those end fins machined down a little. |
pete-stevers |
Sep 20 2005, 11:54 AM
Dan your imaginary friend must have forgotten my name....... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) i've never been called Randy before..
echocanyons |
Sep 20 2005, 12:11 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
What is the consensus of the updated Camshaft Oil Line Restrictors
Worth it or waste of money? Seems like this would be the time to do this |
ArtechnikA |
Sep 20 2005, 12:18 PM
not enough money for it to be wasteful. i did it to my 2,2 and figure it got me at least another year of service. i donno about using them on a fresh engine, although the factory did. but by the time the factory did, cam boxes had 4 bearings. (i guess that was co-incident with the 3,0 so if you have one of those or newer, there's your answer...) i'll probably use them on the 2,7 - thanks for reminding me :-) i'd probably use them - especially with a synthetic oil. definitely if you have hot oil pressure issues, or too-hot oil in general. or spend a lot of time on the track. if you have an uprated oil pump - i donno. now we're getting into uncharted territory again... |
John |
Sep 20 2005, 12:25 PM
One suggestion.
Put a new belt on it before you put it in the car and save yourself a headache if an old one fails with the engine in the car. just my $0.02 |
J P Stein |
Sep 20 2005, 12:35 PM
I dunno, the factory seemed to think it was a gud idea. Better check with the Captian to see if they were right (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
pete-stevers |
Sep 22 2005, 10:56 AM
any more ideas......from the six guys (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Gint |
Sep 22 2005, 12:04 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Beats me Randy... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I'm learning from your thread. Here's a (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) |
Root_Werks |
Sep 22 2005, 12:11 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) Randy is Goose2 on the club. He asked a question, but the same goes for you on the cooler thing. Use yours, don't step down to a stock 914-6 cooler. Keep the one you have an mod it to work. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Root_Werks |
Sep 22 2005, 12:15 PM
Oh yeah, other than my imaginary friend thinks you have problems, he also says you shouldn't bother with the 915 trans until a later date. The 901 should be just fine with a stock 3.0. Plus you'll just need to buy a flywheel now.
It's up to you, but my imaginary friend thinks it would be best. I gotta go, he says it's time for a break. Pushy bastard that he is. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
0396 |
Sep 22 2005, 04:11 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I have tried to order / located these so call restrictors at a Porsche dealer.. they had no idea what I was talking about. Then some one made a reference to them form the shop.. The parts tech and I spent 1/2 looking through the parts listing...never did find them. So, can you 'PLEASE' provide me an factory part number for these restrictors? Thanks youuuuu (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
ArtechnikA |
Sep 22 2005, 04:20 PM
but of course. i got mine from Pelican. you'll also need 3 new crush rings per side, and the ones they recommend may or may not be the right ones... 901.105.361.01 ETKA calls this an "intermediate piece" it will have a circumfrential groove around the hex to indicate it is the new part. |
0396 |
Sep 23 2005, 08:23 AM
Thank you! |
J P Stein |
Sep 23 2005, 09:34 AM
The "restrictor" is now the only part they carry. Found that out when I went lookin' for them at the dealer.
Makes things simple, eh? |
sixnotfour |
Sep 23 2005, 10:25 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the original style is .00 the upgraded is. 01
Mugs914 |
Sep 23 2005, 10:27 AM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
This may be so obvious as to not need mentioning, but I'll mention it anyway...
Be sure to cut a hatch in the firewall right in front of the fan so that you can get at the front of the engine to set ignition timing, fan belt changes, etc.. Make it about as wide as the flat part of the "hump" between the seats and about 10" high. Make a cover out of aluminum or something and be sure it fits pretty well (to keep out fumes and such). The back pad covers it up and you'll never know it's there until you need it, but when you do... (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) Another thing I did was to cut the top of the fibreglass fan shroud to make a removable piece so I can get to the back of the alternator. My alt. failed once and it's pretty much impossible to get out with the engine in the car unless you can remove the top of the shroud. The pic isn't great, but you get the idea. I made a lip out of thin aluminum that closes the gap on the inside and small clips on the outside. The bolts on the fan housing hold it in place. The more I can do without pulling the motor the better, I figure... (Lazy bastard theory at work, here.) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Attached image(s) |
Mugs914 |
Sep 23 2005, 10:29 AM
Here's another pic...
Lo-Fi Version | Time is now: 17th May 2024 - 05:21 PM |
