Injector flow rates?, What's good |
newto914s |
Sep 19 2005, 10:01 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
My heads are running a little hot and since I can't find any vacuum leaks and my injectors are miss-matched(two green stock 76, and two blue volvo injectors-280 150 024) I thought I'd check their flow.
All four appeared to have a nice spray, here are the numbers I got. This is over a 5 second crank, cold engine, and my Mom as the assistant(so figure in with the margine of error (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) #1) .85ml out of 7 pulses #2) 1ml out of 8-9 pulses #3) 1.1ml out of 8 pulses #4) 1.15ml out of 9 pulses #3&4 are the blue injectors, I was going to order some new ones to have a matching set(greens), but mabye I shouldn't if they're flowing more. What do you think? Samson |
newto914s |
Sep 20 2005, 05:49 AM
OK, I should have done a search first, their are a number of posts that show the flow rate. 380cc/min.
How would I change the numbers that I have to compare them to cc/min Also, if the injectors are close, how important is it that they are matching(I guess I'm thinking in term or resistance) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:45 PM |
