My heads are running a little hot and since I can't find any vacuum leaks and my injectors are miss-matched(two green stock 76, and two blue volvo injectors-280 150 024) I thought I'd check their flow.
All four appeared to have a nice spray, here are the numbers I got. This is over a 5 second crank, cold engine, and my Mom as the assistant(so figure in with the margine of error
#1) .85ml out of 7 pulses
#2) 1ml out of 8-9 pulses
#3) 1.1ml out of 8 pulses
#4) 1.15ml out of 9 pulses
#3&4 are the blue injectors, I was going to order some new ones to have a matching set(greens), but mabye I shouldn't if they're flowing more.
What do you think?
Samson
