Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
I've had some oddball ideas in the past.....I think that one takes the cake, hahahahaha now I've wasted about 20minutes surfing the 'net for info on those motors...it appears a new V-block would have to be made since the cylinders are not seperate like the motorcycle engines, also I think the 3 bangers are only 2 valves per cylinder (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
Hey Again Mike..
thought they were 4 valvers.. oh well. I was thinking of cutting off the bottom or each block, so you'd have aluminum heads, iron block, and aluminum crankcase... hey, Triumph makes a 4 valve 900cc triple..... they are loosely based on Kawasaki architecture (very very loosely)... For Wacky engine ideas.. look no further than your "History of German (and British) Motorcycles" the've already tried it all. (Ariel Square Four.. I rest my case) Other Casting Ideas: Type IV Flat-6 or Flat-8.. forget about improving the crappy combustion chambers,, just add more of them.... all you need to do is carve up some old crankcases to use as male mold Type I Flat-6/Flat 8.... Harley Davidson Heads for Above engines.... (tons of aftermarket choices)... BMW R1000 "Oil Head" Pushrod "in Head" units.... try them also.. 4 valves/cylinder. ( I really want the 8... heads are easier than for a 6) 914 Aluminum "banana" trailing arms set up for 911 rear end parts.. Improved 901 Transaxle casting.. stiffer, meatier.. un-cantilever 1st gear while your in there.. Aluminum Engine Mount Bar - take some weight off the car Aluminum Heater Boxes and "Flapper" boxes.... |
neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
You may have something there...just make it cheaper than a 915 or 930 and you can sell to the V8 and mid-engine replicars enthusiasts. |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Wicked sh!t man. I like the ingenuity. The quality looks amazing.
I think new improved TIV cases and heads would be da bomb! |
Lo-Fi Version | Time is now: 3rd July 2025 - 02:54 PM |
