| Air_Cooled_Nut |
Sep 22 2005, 11:13 AM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Okay, seems I have some oil leaking from the valve covers. The engine has new valve covers and seals. Installed dry. One thing I did notice -- and this may be the issue -- is that it appears that the valve covers were spray painted black. The entire cover. Would this [thin] paint compromise the integrity of the seal? I have the necessary tools to remove the paint if that's the issue. Or do the seals need Gas-A-Cinch or other sealant on them? If so, which side (head side or cover side)?
TIA again! |
| Tobra |
Sep 22 2005, 11:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
I was advised by a Porsche mechanic friend of mine that the gasket cinch would be helpful. I would not put it on the head side. Used to use a bit of grease on the type 1 motor in the Super Beetle to accomplish the same thing,hold gasket in place whie cover is installed.
| rhodyguy |
Sep 22 2005, 11:41 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
cork or rubber gaskets? check the edges and see if they are bent or deformed. the covers i had coated recently had a hard black finish on the inside. laquer thinner had no effect. the guy that did the blasting said it was pretty though. vw emblem on the inside, upside down?
k |
| Joseph Mills |
Sep 22 2005, 12:12 PM
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
On my cork gaskets I use Permatex Hight Tack Gasket Sealent on the valve cover side only of the gasket. Let the sealent set up for about 5 minutes before fitting the gasket to the valve cover.
My covers are coated with a glossy epoxy paint finish. Not a single leak yet. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) .. |
| Cap'n Krusty |
Sep 22 2005, 12:14 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The tab on the cover goes on the bottom. The bails curve UP from their pins. Use Gasgacinch on the gasket AND the cover, and let it air dry before slapping them together. Use the rubber impregnated gaskets. CLEAN the sealing surface of the heads. The Cap'n |
| Air_Cooled_Nut |
Sep 22 2005, 12:18 PM
Yes, VW upside down...I remember reading that here.
Rubber gaskets. On my VW I use the cork ones and that are great! Hmm...I'll Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
| Cap'n Krusty |
Sep 22 2005, 01:44 PM
If the bails are installed correctly, thyey swing down and the covers come right out. If they're upside down, the covers won't clear them, and the correct pressure won't be applied to the covers. The Cap'n |
| rhodyguy |
Sep 22 2005, 02:45 PM
while changing a gasket out on the side of the road, i spent about 15 min trying to work/fight around the tire. took off the tire and i was done with the vc in 2 minutes.
k |
| Michael J |
Sep 22 2005, 07:38 PM
Welcome to 2007 ![]() ![]() Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
I cleaned the covers and replaced the gaskets with cork and added a very thin layer of copper gasket sealer. But @!$&* it still leaked. Got it up on the jack stands and found it was the push rod tubes that were leaking but running down and dripping off the bottom of the valve cover.
| SGB |
Sep 22 2005, 08:10 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I've never used "gasacinch". Does it not stick (residue wise) to the inside of the cover if you let it dry? I never had leaks- until after I overfilled the case by misreading the dipstick halfway through a long trip. I've only ever seen cork gaskets... and I'll check to make sure the bails are on right. Anyway, the time I got the leak the gasket was curved up inward toward the valve chamber- and the replacement I got also wanted to bow in. I think the bearing grease idea might address this. Of course, so will that gasacinch stuff- who makes that anyway? |
| Air_Cooled_Nut |
Sep 22 2005, 11:39 PM
The GAC worked like a charm, thanks for the tip! While I was at the import part store buying all new hoses I bought the cork gaskets and installed them. The oil was indeed coming from the valve covers.
Removing the bails looked difficult but I found that my reallllllllly long screwdriver (12" or so and fat!) worked great at prying the bails off (down) and on (up). After I removed the heat exchanger air inlet and lower duct (the one w/the cable actuated flap). Oh yeah, all new hoses in the engine, including the front fuel emission ones! |
| rhodyguy |
Sep 23 2005, 07:11 AM
| Air_Cooled_Nut |
Sep 23 2005, 09:28 AM
Check out my blog and you'll see where I put my fuel pump...in the engine bay (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) The blog entry explains why. Hey, at least there's all new hoses throughout! Does that yang the yin of the fuel pump location (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Lo-Fi Version | Time is now: 7th December 2025 - 04:12 PM |
