mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
Two questions;
1. which side should the "ridged" side of the ball cage face when installed? towards the axle or away? I think it is away from the axle but I didn't take a good enough 'before' picture to tell (oops). 2. One of the used joints I bought in Ventura is different than the others. It has larger balls and a lot more axial travel than the rest. It shows some wear but not extreme spalling like on the ones I am replacing. Is this a rebuilt joint? Is more axial play normal in rebuilt joints? Thanks in advance for any help. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I believe they go away from the axle. I too have found a couple CV's with different cage and ball sizes, my guess they are rebuilt units - and yes lots of play.
mightyohm |
The joint is still fairly "tight", nowhere as loose as the ones I am replacing. I think I'll put it on and see what happens.
(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
TravisNeff |
These were better than the ones I replaced, but still not that great, so far so good!
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,258 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i dis-agree ... the "ridge" side of the inner race is what slides on the axle shaft, the flat side faces towards the outside where the clip goes ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,309 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
mightyohm |
Andy are you talking about the inner race or the cage that retains the balls?
I am referring to the cage - the thing that goes in between the two races. Wish I had taken a pic last night. Will take one tonight. |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
When working on multiples of things, never have all of them apart at once. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
This is especially important when working on drum brakes, something we fortunately don't have to worry about on the 914. |
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
small balls may indicate a VW CV joint. What size balls do you have??? HA HA HA. Small balls in the correct CV should be no problem, although the load rating might be less. I had a mix of small balled and large balled CV's on one 914, niether one gave any problems driving a stockish 1.7 car.
good luck |
Grimstead |
Cheaky Monkey ![]() ![]() ![]() Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California ![]() |
Jeff,
My engine & tranny are out if you want me to take some pictures of my CV's. Just let me know. |
uhm, my cage dosn't have ridges. it's symmetrical ... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
mightyohm |
Here are the ridges. The other side is smooth.
Ignore the fact that the center race is installed upside down. Attached image(s) ![]() |
ok, i'm looking at my 944 CVs as we speak and the cage has no ridges on either side. perfectly smooth ... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
i think jeffs are 914/4 (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
914werke |
I just chked my /4 CV/s that I had dissasembled and shor' nuf, I see what jeff is describing but danm if I can see what differance it would make? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
mightyohm |
These are 914-4. I think the inner race only fits into the cage from the ridged side, because the opening is a little larger. So there is a difference...
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
In the remaining pile of CVs here at the shop, there's a mix of large and small sizes. As I recall, the new ones I sold last spring were the same way. Could be from different production runs. Porsche calls Lobro and asks for thickness, spline count, and OD. As long as the degree of angular movement is sufficient, the actual design doesn't really matter. The Cap'n |
Lo-Fi Version | Time is now: 18th July 2025 - 11:05 PM |
