Guage bezels, How do you remove them? |
Targa |
Sep 23 2005, 05:45 PM
V Member Group: Members Posts: 180 Joined: 26-December 02 From: San Mateo, CA Member No.: 18 |
I am cleaning up some early guages to backdate my '75. Has anyone else done this? I already see that the late model tach has one indicator for the turn signal and the early has two. How do I change this so I can get left and right signal individually? Has anyone used the 300 degree oil temp combo guage replacement from Palo Alto Speedo? Thanks.
Dave_Darling |
Sep 23 2005, 05:53 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Pry, very carefully. Pelican has a "gauge refurbishment" article in the Tech Articles section of their (our) website; take a look and you'll see how it's done.
If you want to have separate left and right indicators, you will have to do some re-wiring of the instrument cluster. Tap into the wires that go to the turn signals to power the indicators, and tape up the single wire that currently goes to the indicator. The few 74s that had 73 instruments simply wired both indicators to flash when either turn signal was on. --DD |
dakotaewing |
Sep 23 2005, 05:57 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Dave... Where ??? and how.. and with what tools?? |
Targa |
Sep 23 2005, 06:15 PM
Thanks Dave. I forgot to even look on the bird board.
Dave_Darling |
Sep 23 2005, 07:14 PM
Thom, check the tech article. It goes into detail. Where? Back side of the bezel, where it sits against the rubber. With what? A small screwdriver or whatever implement of destruction you fancy. How? Very carefully.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) --DD |
Joe Bob |
Sep 23 2005, 07:46 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
A spade pointed dental pick works the best.....
Lo-Fi Version | Time is now: 19th May 2024 - 09:57 PM |
