| Triaddave |
Sep 25 2005, 11:23 AM
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
O.K. so i built this big four banger. a 2.4 l,big bore four. all the goodies,rad cam,big valves,dual springs,103mm pistons on stock stroke rods.lightened flywheel and 44idf webers. the engine wouldn't run on the 50 mains, but the 60's seemed to make it screem. and screems it does! great low end tork and the top end comes up fast.
the engine is great, but the mileage sucks. i put 8 gals for a day at the race track.usually plenty for the drive up and back, two drivers with fun runs. so hear it is, low on fuel at 100 miles! less than 10 to the gal,more like 8 something. do i have a issue going on? the engine seems to run like a raped ape,but i expected a bit more on the mileage dept. any ideas? |
| bd1308 |
Sep 25 2005, 11:49 AM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
isnt there a main between 50 and 60?
try that (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
| Triaddave |
Sep 25 2005, 11:53 AM
sure there is, like 55's. i was limited to what i had in stock. but i'm not sure that the mains are the problem.i'll pull out the plugs today to see how they are burning. i did have a issue before race day with the manifolds coming loose at the heads,fixed.
| bd1308 |
Sep 25 2005, 11:56 AM
i figured that isnt the solution.......
b |
| dmenche914 |
Sep 25 2005, 11:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
14 mpg in a 3.8 liter V6 powered 914 with Holley 4160 headers, cam, and a slightly heavy foot.
| J P Stein |
Sep 25 2005, 12:21 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I went thru about 3 gal in 10 passes at an SCCA AX practice event....and ran out on that 10th.
| rhodyguy |
Sep 25 2005, 12:54 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
hard charging dave. i bet with regular driving you would see better mileage such as on the freeway. i think i get in the upper 20's on the freeway just cruising. zipping around town in 3rd results in $40 fillups on a regular basis. you may have to install a bung on the final someplace and run an 02 sensor/gauge to figure where the A/F mixture is at.
k |
| Aaron Cox |
Sep 25 2005, 12:56 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
Dave - what are some specs on the motor?
bore/stroke etc |
| redshift |
Sep 25 2005, 01:04 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Bigger than your's.. all you need to know.
(IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) M |
| rhodyguy |
Sep 25 2005, 01:12 PM
103x71 aa. a bit of confusion. you mean 50 & 60 on the idles? pull the main stack and check the numbers on the main jets, should read 1xx something, air correction and the emulsion tubes also.
k |
| olav |
Sep 25 2005, 01:26 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
I get about the same gas mileage too. 55 idle and I forget my mains. Goes like stink though. If I drive in 5th everywhere I can get 200 out of a tank. |
| Brando |
Sep 25 2005, 01:35 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Triaddave... did you forget you have a 5th gear? (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
I can believe that low of mileage on a 2.4... Do you drive it in the high RPMs all the time? With the 44s open all the way, you really can flow a lot of air/fuel through there. If you keep it at 3000 - 3400 rpms when crusing you should see a lot better mileage. Your motor sounds hot... I need new undies. |
| rhodyguy |
Sep 25 2005, 01:47 PM
+, must be 100miles round trip just driving to bremerton and back. they run quite long courses at bremerton, with lots of 2nd gear. 2 drivers=6 passes (minimum) + fun runs. wide, sticky ax tires. long line ups and idling if you don't shut it down. a bit of stop and go from your place to I-5. it adds up. not surprising that the milage seems low.
k |
| URY914 |
Sep 25 2005, 01:51 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,438 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I use to go through gallons and gallons of gas when I did track events.
I mean you're on the gas to the floor or on the brakes to the floor. What's want? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
| rhodyguy |
Sep 25 2005, 01:54 PM
the triad crew are all "on throttle" all the time.
k |
Lo-Fi Version | Time is now: 3rd March 2026 - 02:21 AM |
