6 cyl alternator mount question, something's wrong |
2teeners |
Aug 6 2003, 06:39 AM
Member Group: Members Posts: 79 Joined: 2-January 03 From: Arlington DFW, TX Member No.: 78 |
is there a special nut that holds the alternator to the frame, under the cooling shroud? I have a plastic duct that attaches to the 6 bolts coming through the alternator and frame and normal nuts would smoosh the plastic at a torque tight enough to hold the fan from scaping it's frame. and the threads don't stick out far enough for a double nut and lower torque.
The engine is an early 70's 2.2, if that matters. Any help would be appreciated. (IMG:style_emoticons/default/clap56.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 02:35 AM |
