Wiring Harness Removal, Serious Chopping |
McMark |
Sep 29 2005, 12:05 PM
Here's the trash wires and the wires that will go back in. This is going into one of our members race cars. The only things left working will be fuel pump, gas tank sender, brake lights, tach, generator light, oil pressure light, and reverse lights. I took apart the stock harness so all the wires will be original, but all the extra wires will be gone. I'm heading out later today to start weighing all the stuff I've removed on a very accurate food grade scale. I'll keep ya'll posted.
McMark |
Sep 29 2005, 12:06 PM
We don' need no stinkin' pictures! (IMG:http://www.914world.com/bbs2/html/emoticons/pinch.gif)
brant |
Sep 29 2005, 12:21 PM
You'll need the alternator wiring too.
We did this on our race car, except we bought aircraft wire from Spruce supply because it has lighter weight sheathing and saved weight on the insulation and connections too. Its amazing how much weight there is really. also, you can run a single wire to the brake lights. Put their ground on the chassis and get rid of some of the extra brake wiring. |
lapuwali |
Sep 29 2005, 12:30 PM
Yup. Look for my rewiring thread. There's a diagram of a minimal (as in racecar) setup there, plus a charging system diagram. If you're running no alt, just don't do the charging system part.
brant |
grounds:
McMark |
Sep 29 2005, 12:51 PM
The car is getting LINK, so I haven't done anything for the engine wiring harness. This is just the body wiring, so the alternator wiring will be included. Great idea on the brake light wiring.
IronHillRestorations |
Sep 29 2005, 07:26 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Don't forget to add the momentary contact switch on the steering wheel, for the brake lights (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Cire |
Nov 1 2009, 09:32 AM
Member Group: Members Posts: 279 Joined: 12-March 09 From: Tucson, Arizona Member No.: 10,155 Region Association: None |
Yup. Look for my rewiring thread. There's a diagram of a minimal (as in racecar) setup there, plus a charging system diagram. If you're running no alt, just don't do the charging system part. I cant seem to find your thread on the minimal wiring setup. I too am in need of a very simple wiring harness. Also, with your experience, is it better to keep the old 914 wiring harness and go through it and remove all the old wires or is it better to start over? I have my car 98% of the way done and am just looking at the dash and all the wires and am afraid to jump off the deep end. =) Thanks. Eric |
ConeDodger |
Nov 1 2009, 10:27 AM
Apex killer! Group: Members Posts: 23,583 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yup. Look for my rewiring thread. There's a diagram of a minimal (as in racecar) setup there, plus a charging system diagram. If you're running no alt, just don't do the charging system part. I cant seem to find your thread on the minimal wiring setup. I too am in need of a very simple wiring harness. Also, with your experience, is it better to keep the old 914 wiring harness and go through it and remove all the old wires or is it better to start over? I have my car 98% of the way done and am just looking at the dash and all the wires and am afraid to jump off the deep end. =) Thanks. Eric Eric, The post you have responded to was written by James Montebello (Lapuwali). He passed away two or three years back. He is memorialized with the Lapuwali Classic Threads in another section. Perhaps someone else will step up and answer your question... |
Lo-Fi Version | Time is now: 12th May 2024 - 12:31 AM |
