Possiable Rattle, Heat exchangers |
Eric Taylor |
Aug 6 2003, 10:23 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Right now I've got the heat exchangers and muffler out of the car, and on the drivers side, the acutal exchanger which wraps the tubes is loose. In fear of rattle I want to do something about it, so what can I do short of welding it back to the tubes? Can I just use some epoxy or something?
Thanks, Eric |
Brad Roberts |
Aug 7 2003, 12:07 AM
It doesnt weld to the tubes... its "clamped" from the factory. You might be able to re-pinch the weak area's and spot weld them...but it wont hold. I have yet to see a home fix work for any length of time.
B |
Aug 7 2003, 03:53 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
One that worked pretty well for my old 1.8 for a few years (1 of driving, 2+ of sitting) was to put large hose clamps around the individual tubes at the back. The "wrapper" part had rusted away right at the back, the way they all seem to eventually, and a couple of hose clamps pushed the wrapper forward a bit and provided a large enough surface to keep the wrapper from rattling.
The correct solution, though, is a set of SSIs. (IMG:style_emoticons/default/biggrin.gif) --DD |
Lo-Fi Version | Time is now: 29th May 2024 - 05:24 AM |
