> I'm joining the second 914 club! (again), It's got webber issues though...
bondo
post Oct 2 2005, 08:13 PM
So I got me a second 914, to drive while I finish restoring the "keeper". But it has dual webber 40's with issues.. It doesn't like to idle, and if I spray carb cleaner into some of the venturies it idles better, others not. Should I just pull them and rebuild them? Turning the adjustment screws doesn't seem to make much difference.
I'm trying to acertain whether or not it has the stock cam, if it does I'll probably go back to fuel injection.
bondo   I'm joining the second 914 club! (again)   Oct 2 2005, 08:13 PM
phantom914   The quickest way to get it working would be to swa...   Oct 2 2005, 08:50 PM
trekkor   the Weber's will work nicely on your motor. c...   Oct 2 2005, 09:03 PM
SirAndy     Oct 2 2005, 09:26 PM
Gint   Those IDF's are notorious for clogged idle jet...   Oct 2 2005, 09:30 PM
bondo   Thanks for the info.. The PO says he has the hayne...   Oct 2 2005, 10:22 PM
Gint     Oct 2 2005, 10:30 PM
bondo     Oct 2 2005, 10:43 PM
V6914   PURPLE is faster than Yellow.   Oct 2 2005, 10:58 PM
Joseph Mills     Oct 2 2005, 11:33 PM
jonwatts   It's [b]POIPLE! Over [color=green][b]GREE...   Oct 3 2005, 12:23 AM
TonyAKAVW   BAH! It looks like a perfect candidate for a ...   Oct 3 2005, 12:33 AM
bondo     Oct 3 2005, 08:40 PM
bd1308   oh shit! what's that crack....Z could giv...   Oct 3 2005, 08:42 PM
bondo     Oct 3 2005, 08:43 PM
bd1308   oh okay! now about that A4000T ...   Oct 3 2005, 08:46 PM
bondo     Oct 3 2005, 08:51 PM
bondo   ...   Oct 3 2005, 08:52 PM
Aaron Cox     Oct 3 2005, 08:53 PM
bd1308     Oct 3 2005, 08:56 PM
markb   The cowl we cut out will work nicely to fix that. ...   Oct 3 2005, 09:02 PM
Aaron Cox   CB linkage kit. its the bomb dot com   Oct 3 2005, 09:12 PM
Travis Neff   That'd be a 1973 ROW 1.7 with an EA code 0-68 ...   Oct 4 2005, 12:12 AM
Joseph Mills   Actually the connecting rod supports "look" adequa...   Oct 4 2005, 07:48 AM
bondo     Oct 4 2005, 09:24 AM
SLITS     Oct 4 2005, 09:28 AM
mikelsr   Are there additional springs on the throttle linka...   Oct 4 2005, 10:58 AM
bondo     Oct 4 2005, 11:23 AM
bd1308   that angle will give you most of your problems.......   Oct 4 2005, 11:46 AM
mikelsr   Are you talking about the return spring on the car...   Oct 4 2005, 03:05 PM
Joseph Mills     Oct 4 2005, 10:39 PM
rhodyguy   what i don't care for on the cb linkage is the...   Oct 5 2005, 08:18 AM
- Lo-Fi Version Time is now: 14th July 2025 - 08:31 PM
