I need help with rear trunk torsion bar, How do I get the bar behind the roller? |
Doug Leggins |
Oct 4 2005, 08:55 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
The teener kicked my ass tonight! I simply wore myself out trying to get the rear trunk torsion bar behind the trunk roller.
I searched for as much info as I cold find before beginning this task. I modified my 12" adjustable wrench as mentioned on other threads on this topic. This tool proved to be a very good lever for pushing the torsion bar back. I could get the torsion bar pushed/twisted back well enough but I could not get it around the hinge roller/pin. I tried several times but could not find a way to get the roller behind the pin on the hinge. I tried to remove the hinge then hold the torsion bar back as far as I could and then reinstall the hinge -This is the task the wore me out! No matter how or what I tried I could not find a way to get the bar behind the roller. Anyone know the secret/technique to get the torsion bar in place? Here is a pic of the wrench with a notch cut out on the end. Attached image(s) |
Mikey914 |
Jun 1 2020, 11:55 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We just brought on McMark's tool for doing these. If anyone needs one I will have them at $29.99 a pop
http://www.914world.com/bbs2/index.php?sho...+spring+tension Attached image(s) |
