I need help with rear trunk torsion bar, How do I get the bar behind the roller? |
Doug Leggins |
Oct 4 2005, 08:55 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
The teener kicked my ass tonight! I simply wore myself out trying to get the rear trunk torsion bar behind the trunk roller.
I searched for as much info as I cold find before beginning this task. I modified my 12" adjustable wrench as mentioned on other threads on this topic. This tool proved to be a very good lever for pushing the torsion bar back. I could get the torsion bar pushed/twisted back well enough but I could not get it around the hinge roller/pin. I tried several times but could not find a way to get the roller behind the pin on the hinge. I tried to remove the hinge then hold the torsion bar back as far as I could and then reinstall the hinge -This is the task the wore me out! No matter how or what I tried I could not find a way to get the bar behind the roller. Anyone know the secret/technique to get the torsion bar in place? Here is a pic of the wrench with a notch cut out on the end. Attached image(s) |
jrmdir |
Aug 10 2021, 08:57 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Older thread but Doug still deserves kudos for the write up and photos of the sectioned crescent wrench technique. I tried all day Saturday (and busted my a##) with a set up that I thought would work using 1/2" square steel tubing for leverage but couldn't figure out how to hold the spring up in order to get another "bite" on the end. On Sunday, a $9 Harbor Freight wrench and about 7 Dremel disks later and I was able to finish the job in about 5 min. Fantastic!
Thanks again Doug! Ron |
NARP74 |
Aug 10 2021, 09:58 AM
Senior Member Group: Members Posts: 1,067 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Older thread but Doug still deserves kudos for the write up and photos of the sectioned crescent wrench technique. I tried all day Saturday (and busted my a##) with a set up that I thought would work using 1/2" square steel tubing for leverage but couldn't figure out how to hold the spring up in order to get another "bite" on the end. On Sunday, a $9 Harbor Freight wrench and about 7 Dremel disks later and I was able to finish the job in about 5 min. Fantastic! Thanks again Doug! Ron How did you determine the location of the JWest brackets? I have them and the tool to do this job. Was the engine installed when you did it? |
ClayPerrine |
Aug 10 2021, 01:21 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
How did you determine the location of the JWest brackets? I have them and the tool to do this job. Was the engine installed when you did it? I bolt them to the hinges, and put the lid on the car. Then I mark where the brackets are on the walls. Then I take the lid back off, and line up the hinges with the marks I made. Once they are on the body, I can adjust them up and down to make the decklid fit perfect. Clay |
