Runoffs Photo Diary, lots of pictures |
ChrisFoley |
Oct 5 2005, 07:15 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Pounding stakes for the tent early Sunday.
ChrisFoley |
Oct 5 2005, 07:16 AM
The tents are ready for raising.
ChrisFoley |
Oct 5 2005, 07:17 AM
The first pole is placed.
ChrisFoley |
Moving right along
ChrisFoley |
Oct 5 2005, 07:20 AM
Caption this photo.
"How many old 914 drivers does it take to put up a tent?" Attached image(s) |
ChrisFoley |
Oct 5 2005, 07:21 AM
The tents are up before lunch.
ChrisFoley |
Oct 5 2005, 07:22 AM
Erik's mom likes the tent. It's nice and shady!
ChrisFoley |
Oct 5 2005, 07:24 AM
Working hard on Erik's car. The Kodiak wheels that were loaned to him required longer wheel studs. All the old ones were removed by Dmitry while Erick made phone calls. No one local had any 100mm studs so they were overnighted to the track from PP.
ChrisFoley |
Oct 5 2005, 07:26 AM
Chris' battery gets a charge after every session.
ChrisFoley |
Oct 5 2005, 07:28 AM
2 race cars under the tent, being readied for action.
ChrisFoley |
Oct 5 2005, 07:29 AM
ChrisFoley |
Oct 5 2005, 07:35 AM
Erik's car is up on my portable alignment platform.
My trailer can be raised up on adjustable legs and leveled. Once set up I can do toe, camber and corner balance on 914s, anywhere I take my car. We both used this twice during the event, the second time after spinning across a curb in Thursday qualifying at fairly high speed. Erik had a slightly bent trailing arm causing 2 degrees of negative camber on the left rear, and I had an inch of toe in up front due to a bent steering arm. Attached image(s) |
ChrisFoley |
Oct 5 2005, 07:36 AM
Its a good thing we had a lot of time because there was a lot of work to be done.
Here Erik makes a ride height adjustment at the left rear corner of his car. Attached image(s) |
ChrisFoley |
Oct 5 2005, 07:39 AM
Kevin and his crew working on the carbs.
ChrisFoley |
Oct 5 2005, 07:42 AM
Chris does a valve adjustment with help from Len Hoffman.
Now Chris understands the special procedure involved in accurately measuring the lash with a long duration camshaft. Attached image(s) |
ChrisFoley |
Oct 5 2005, 07:44 AM
Chris adjusts the idle mixtures while Mark Peebles watches the guages.
ChrisFoley |
Oct 5 2005, 07:46 AM
Tom spent a lot of time working on throttle cable issues.
ChrisFoley |
Oct 5 2005, 07:49 AM
Cathy and Dorothy relax. Dorothy's big job each day was to make sure Erik and his crew get lunch.
ChrisFoley |
Oct 5 2005, 07:51 AM
Tom talks things over with Kevin and crew.
ChrisFoley |
Oct 5 2005, 07:52 AM
Jake has a chat with Erik.
Lo-Fi Version | Time is now: 13th May 2024 - 06:25 AM |
