miking Crank, 40mm 50mm 60mm |
qa1142 |
Oct 5 2005, 07:42 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
1.574" (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
1.968" (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) 2.362" (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) What are inch wear limits? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
qa1142 |
Oct 5 2005, 08:05 PM
Ok
Main's (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) #1 - 1.5743" #2 - 2.3614" #3 - 2.3614" #4 - 2.3612" Rod Journals (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) #2 - 1.9680" #4 - 1.9678" #1 - 1.9678" #3 - 1.9678" And smooth as a baby's (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) |
Type 4 Unleashed |
Oct 5 2005, 08:56 PM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
So the crank is .0002 off, both on the rods and mains, that is so bad, it's not worth even polishing, you should just send it to the crank grave yard, (where all the worn out cranks go) or just send it to me, I'll take good care of it, I'll lay it to rest, (between case halves) (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
Jake Raby |
Oct 5 2005, 09:23 PM
Build that bitch...
Those measurements are typical- these cranks just don't wear unless someone runs them low on oil, or runs quaker sludge or pennzoil... |
qa1142 |
Oct 6 2005, 05:44 AM
Jake
I am waiting on your parts to "build that bitch" (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Did my stuff come in? |
Jake Raby |
Oct 6 2005, 09:06 AM
Still waiting on cams... I simply cannot keep that particular cam in stock no matter how hard we try- it moves like mad!
qa1142 |
Oct 6 2005, 09:40 AM
looks like the madness has moved to your avitar
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 03:42 AM |
