exaust?, whats better? |
shaggy |
Oct 5 2005, 09:34 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
right now i have a stock 1.7
id like to make it faster i am now using the stock vw exaust if i was to switch to a monza exaust would that help me at all? if i was to do this should i switch my pipes too? id like to get a better exaust (if there is one) at a reasonable price. does anyone have any suggestions? what do you guys, that go for speed, use? |
Trekkor |
Oct 5 2005, 09:40 PM
I use a pair of 3-into-1 headers, a dual quiet pack Ansa exhaust with a crossover...and a SIX attached to that. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
KT |
bd1308 |
Oct 5 2005, 09:43 PM
for run-of-the-mill engines, the Triad exhaust works pretty well.....
I believe the real bottleneck (as far as exhaust goes) is the HE's..... somebody makes a replacement header system, it's supposed to improve things by a noticeable percentage....I'm not 100% who it was, so I will just leave it at that. b |
914fan |
Oct 5 2005, 09:48 PM
Member Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
Do a search on monza, bursch, SSI, tangerine, kelly hunter, triad, and ansa. There is lots of info out there.I believe the order is
Tangerine Triad SSI with Bursch Kelly Hunter SSI with stock stock with bursch stock with monza (ansa?) stock with stock. I could be wrong I have a monza for sale if you would like. PM me $75 |
shaggy |
Oct 5 2005, 09:54 PM
HAHAHAHAHAHA (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) !!
if i had the cash for a 6 it would be in there already! still workin' on that, but maybe eventually that "Ansa" exaust, what do those things cost? do you have any suggestions for the headers? |
Mueller |
Oct 5 2005, 11:42 PM
if you need heat, you are limited to heat exchangers with a new muffler on the end....a new Bursh is your best value, the Triad supposed to sound the best...I've never seen dyno comparisons between the mufflers, as far as I know, they all perform about the same, just sound, weight and looks are what seperates them...some people like the 4 tip ansas, since they like the all looks and no go (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
headers will give you a few more HP and gain some performance from a lighter weight assembly, bring cash, they "start" at $400 and go up from there really fast. For headers, European Racing is more in your price range I believe (see vendor section) and if you do have money, the best is from CFR, the Tangerine Racing header...these start at just under a $1000 with no muffler included (I could be wrong) Oh, and for a stock motor, all that money will gain you about 5hp if you are lucky on that motor.......of course if you are lucky, you won't break and exhuast stud removing the old exhaust if you go the header route, then start adding more money to the mix.... |
shaggy |
Oct 5 2005, 11:58 PM
it dosent get that cold here in az and if it does i have a jacket (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) besides, my heater isnt working anyways (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
id really like to just drop the extra weight, but i have to convince my dad of that first would pipes-heat exchangers give me ne more hp? if so how much? does anyone make a strait pipe? and if so how much do they run? |
Oct 6 2005, 12:01 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
From what I have read, the Monza and Ansa mufflers will usually make a touch less power than the stock ones--at least, on a 2.0 motor and exchangers. The Bursch is supposed to make a touch more, though there are people who argue that the stock muffler makes more power than the Bursch.
Headers are where you can make real gains. The Kerry Hunter headers are the least expensive (start at around $400) and make the least extra power--up to about 5 HP, probably. The Tangerine Racing ones are the most expensive (about a grand, or more) but are the most effective--I think they may be able to make you 10 HP on a stock 2.0 motor. The European Racing headers are partway between those two in both price and performance. None of them will give you any semblance of heat or defrost. With the possible exception of the Tangerine setup; there is a very small heat exchanger section available as an extra-cost option on at least one Tangerine setup, but I don't know if it fits in a 914 or not. If you want heat, stock exchangers or SSIs are your only real choices. --DD |
Mueller |
Oct 6 2005, 12:09 AM
you alread have heat exchangers, they come standard on the car......basicly what they are is individual tubes with sheetmetal around them... they should look something like these: (IMG:http://i11.ebayimg.com/03/i/04/80/d7/b8_12_sb.JPG) all four pipes join up at the muffler a true header looks like this: (IMG:http://www.914world.com/bbs2/uploads/post-2-1051741143.jpg) no real place to put a straight pipe beware of stupid people on eBay, currently there are 3 ads for "headers"....they are NOT headers...2 of them are heat exchangers and 1 is an exhaust pipe that connects the heat exchangers to a muffler (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
Brando |
Oct 6 2005, 12:53 AM
Mufflers on a header are wasteful! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
If you don't want the heat, go headers. If you want heat, replace with early 2.0-style SSIs and get the necessary heater equipment, which you probably have already. |
Hammy |
Oct 6 2005, 01:14 AM
I thought they were the same thing ? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
McMark |
Oct 6 2005, 01:47 AM
Unless you're ready to drop at least $1000 on an exhaust system, don't bother. The best thing you can do for speed/power is start saving and shopping for a 2.0. That will give you the biggest bang for your buck.
ArtechnikA |
Oct 6 2005, 05:53 AM
SSI is a brand of stainless-steel aftermarket heat exchangers. SSI == HE HE != SSI i will let others discuss the costs and benefits. the grim reality the aftermarket *muffler* people don't want you to know is that most of their products make LESS HP than the stock stuff. you can change if you like the look, or the sound - but most of us have an uncomplimentary adjective for products that are put on a car for "the look" while making it run worse -- " the 'R' word' ... and do not lose sight of The Bigger Picture... you can spend $2000 increasing the output of your 1,7 4-5HP. that might be better directed to something like a 2056 kit... |
Lo-Fi Version | Time is now: 11th May 2024 - 10:56 PM |
