not so technical how to, vapor barriers for dummies |
rhodyguy |
Oct 6 2005, 07:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
starting point.
k Attached image(s) |
rhodyguy |
Oct 6 2005, 07:32 AM
remove the screws holding the lower trim piece on the handle and slide it forward to take it off. in addition to the upper screw on the grab handle there is one on the lower front you must also remove to pull the door panel.
rhodyguy |
Oct 6 2005, 07:34 AM
i found this method works best so you don't tear the clips out of the fiber board backing.
rhodyguy |
Oct 6 2005, 07:35 AM
my door was very clean inside. now would be the time to tidy yours up and treat any rust.
rhodyguy |
Oct 6 2005, 07:38 AM
this screw can be a real pain. a squirt with Aerokriol makes the job easier. the retaining nut on the outside too. don't twist the threaded portion off the pot metal!! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
rhodyguy |
Oct 6 2005, 07:41 AM
another shot of Aerokriol on the window tilt adjuster. make sure the screw turns easily. no point in taking the panel back off at a later date.
rhodyguy |
Oct 6 2005, 07:47 AM
what prompted the whole thing. i was visiting with a friend on tues. the pass side outer door handle didn't work. i thought my buddy was going to tear the thing off. harder is better right? i had a new slider handy. i did a test /closing before putting the handle back on. still didn't work. again with the Aerokriol on the interior mechanisim. when you can push on the forked piece inside the door with your finger and the door opens easily, it's good to go.
rhodyguy |
Oct 6 2005, 07:53 AM
i would suggest you use 1mil or thicker plastic for the barrier. painters drops work fine. i found this in a box. i think it was for the jetta. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) . after you get the plastic on, open all the holes for the plastic clips and the 2 grab handle screws. easier than trying to shove the clips through the solid plastic. the adhesive on the
is plastic made it super easy. for plain plastic, i use "Permanent Double Sided Scotch Tape" around the inside of the perimeter where the edges of the plastic are. i wiped the perimeter down with denatured alcohol so it would stick well. trim excess with a utility knife or exactoknife. a RAZOR SHARP NEW BLADE WORKS BEST! k Attached image(s) |
rhodyguy |
Oct 6 2005, 08:02 AM
as Paiynes would state assembly is the reverse of disassembly. other items to consider when doing this. a handful of the plastic/rubber cups the clips push into(i think 8 or 9 per side), new outer squeegees(very inexspensive), inner fuzzy strip(pretty cheap), and window end caps(gpr had some sets the last time i called). the cap has a small screw that goes into the verticle window channel. drop it inside the door with the panel on. and you'll be pulling the NEW barrier!! <!-- emo&:o -->(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)<!-- endemo --> if i was going to go crazy, I would do the vert chanel guide strips(not so inexspensive), but mine were in good shape.
k |
dbledsoe |
Oct 6 2005, 08:06 AM
Mutineer Group: Members Posts: 300 Joined: 13-May 03 From: Boise, ID. Member No.: 687 |
Great info and photos! Thank you for posting this.
type47 |
Oct 6 2005, 08:27 AM
rhodyguy |
Oct 6 2005, 08:35 AM
i did a few edits and added a some second thoughts in the appropriate replies. if you have door panels that aren't all warped, this task will help keep them that way.
k |
Dave_Darling |
Oct 6 2005, 11:55 AM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Nominate this for "Classic" status!!
--DD |
echocanyons |
Oct 6 2005, 12:03 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
good write-up Kevin |
rhodyguy |
Oct 6 2005, 12:46 PM
thank you.
k |
redshift |
Oct 6 2005, 01:11 PM
I just used packing popcorn, and liquid nail.
My doors don't work anymore. M |
SirAndy |
Oct 6 2005, 01:17 PM
Resident German Group: Admin Posts: 41,616 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i'll move this to the classics ...
Lo-Fi Version | Time is now: 4th May 2024 - 01:07 PM |
