not so technical how to, vapor barriers for dummies |
rhodyguy |
Oct 6 2005, 07:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
starting point.
k Attached image(s) |
rhodyguy |
Oct 6 2005, 07:53 AM
i would suggest you use 1mil or thicker plastic for the barrier. painters drops work fine. i found this in a box. i think it was for the jetta. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) . after you get the plastic on, open all the holes for the plastic clips and the 2 grab handle screws. easier than trying to shove the clips through the solid plastic. the adhesive on the
is plastic made it super easy. for plain plastic, i use "Permanent Double Sided Scotch Tape" around the inside of the perimeter where the edges of the plastic are. i wiped the perimeter down with denatured alcohol so it would stick well. trim excess with a utility knife or exactoknife. a RAZOR SHARP NEW BLADE WORKS BEST! k Attached image(s) |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:52 PM |
