Help decode a mystery vin, 119126626 |
Matt Monson |
Oct 7 2005, 09:55 AM
Member Group: Members Posts: 156 Joined: 9-August 05 From: Boulder, CO Member No.: 4,562 Region Association: Rocky Mountains |
So,
I know some of you guys like VIN and engine mysteries. We have a car here that we can't ID. Title says it is a '69 911. It is a T sun roof and a Karmann body with a '68 production date. Engine serial number is 6177521. I am not finding either this engine number or chassis number listed in any of the books I have available to me. The engine serial number starts out like a late '77 2.7l case, but the rest of it doesn't jibe. And the type number has been filed off of it. Any thoughts are appreciated... |
Cap'n Krusty |
Oct 7 2005, 10:14 AM
The chassis number is in the 69-71 book. The engine number appears bogus. Look at the casting # on the side of the case. The Cap'n
ArtechnikA |
Oct 7 2005, 10:25 AM
it'd be a '69 Karmann T - if '69 VIN's went that high...looks like the high-number sequence number is 3561... '617' should be a '67 T but pre-'69 engine numbers were 6 digits.
i don't see the chassis number in the Spec book but the Cap'n has access to more books than i do ... |
Matt Monson |
Oct 7 2005, 10:36 AM
We pretty much figured the engine number was bogus. The stamps are all squirrely, and appears to be restamped. The driver's side case is the correct part number for a 901/16, but there is so much muck, I can't read the passengerside one. We are kind of thinking someone may have mismatched a case. Either that, or when they restamped the case, they were stoned and instead of 6197521, they stamped it with a 7 in the third position. The lengths some people will go to to keep something "numbers correct". It is a 911t for god's sake...
Lo-Fi Version | Time is now: 11th May 2024 - 09:12 AM |
