Brake gurus, here is my suggestion |
DanT |
Oct 8 2005, 05:38 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Here is my plan...unless someone can make a better argument.
So I now have my billet front hubs, so I am going to be running M calipers with Pagid orange in front. With SC vented rotors. For the rear I can either run stock 4 rears or put the stock 4 fronts on the rear. With mid performance or stock pads. Remove the stock proportioning valve and place a T? or leave proportioning valve? Parking brake will be removed regardless because of roll bar interference with hand brake mechanism. Will be running stock 4 bolt Fuchs with "R" rated tires. So give me your best shots, suggestions etc. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Dave_Darling |
Oct 9 2005, 09:58 AM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
T or adjustable valve. The adjustable one is preferred, because you can fiddle the balance if you find it's got too much rear bias. But, according to a number of other people around here, you shouldn't have too much rear bias...
--DD |
KenH |
Oct 9 2005, 10:51 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
"T"
Easier to bleed the brake system. Firm petal. Set bias with brake pads. Also go to 19mm master cylinder. Ken |
Eric_Shea |
Oct 9 2005, 06:48 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Too much rear brake. Porsche didn't go with that much brake on the rear (42mm pistons) until 1984. They coupled it with 48mm front pistons at that time (and a first for a 911... a p-valve).
I would use: M-Calipers up front as stated. 19mm MC as stated. Leave the P-Valve in place "Narrow" Rear M-calipers with 38mm pistons (off a 68-69 911 or later ones, 70-83 with the spacer removed) on the rear. This would give you the exact same configuration as a 914-6 (w/o the parking brake of course) |
goose2 |
Oct 9 2005, 09:50 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 20th May 2024 - 10:00 AM |
