914/6 turbo lower valve cover clearance |
Eddie914 |
Oct 8 2005, 09:07 PM
Unregistered |
How much material needs to be removed from the 930 lower valve covers to allow adequate clearance from the trailing arms to facilitate removal with the engine in the car?
Am I correct in assuming the ribs need to be clearanced at the rear? Thanks, Eddie |
sixnotfour |
Oct 8 2005, 10:23 PM
914 Wizard Group: Members Posts: 10,428 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Easier at this point for you eddie , just to put the motor in then , test fit, grind test fit.
Unless some one has a picture of one done. I just mill the whole thing down. Found the thread; http://www.914world.com/bbs2/index.php?act=...wer+valve+cover This post has been edited by sixnotfour: Oct 8 2005, 10:53 PM |
Lo-Fi Version | Time is now: 10th May 2024 - 04:07 AM |
