I want to buy this ..., muffler but don't know if it .... |
jimkelly |
Oct 9 2005, 11:36 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
will fit 1973/74 2.0 HE's ..
http://www.914world.com/bbs2/uploads/post-1...-1128741230.jpg http://mysite.verizon.net/vzeedoxu/IMG_1157.jpg http://mysite.verizon.net/vzeedoxu/IMG_1158.jpg What do you guys think ?? Jim |
Allan |
Oct 9 2005, 11:41 AM
I'm not sure but it sure looks just like the flange on my 1.7/1.8 exhaust.
SLITS |
It's the street Bursch...I have one....nice setup...go for it!
jimkelly |
Oct 9 2005, 11:45 AM
The problem is that I have a rusty steel 1.7 HE's on my 1976 2.0 now with a leaky banana muffler. I have a pair of 1973/74 2.0 SS HE's in storage. Jim
Does anyone know if the inner diameter of the 1.7 HE's would reduce HP output of a 2.0?? |
Oct 9 2005, 12:05 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Looks a lot like a Bursch. There's a version that fits 2.0 exchangers; I thought there was a version for the 1.7 ones as well. Can't tell from the pic which that is (if indeed there is a 1.7 one).
The 1.7 HE's will probably reduce the power a little bit, but I doubt it'll be much. Probably not enough to feel, and certainly less than the 75-76 exhaust did in the first place. --DD |
SLITS |
Supposedly, the diameter of the SS HE's are all the same (not true with the steel ones).
There is reported to be a gain going from the steel 1.7/1.8 to the steel 2.0 Remmember, you need the HEs, muffler bracket and muffler to make the change. |
bondo |
Oct 9 2005, 12:11 PM
Looks like a 2.0 muffler to me. (upside down though) See how the flange is below the outlet? Well 2.0 HEs go straight back, and 1.7/1.8 HEs make an S curve upward. If that muffler were for 1.7/1.8, the flange would be at least partially behind the muffler part in that view (remember, it's upside down).
Aaron Cox |
Oct 9 2005, 12:17 PM
thow your 2.0 HE's on and get a triad.
www.triadwestperformance.com |
bondo |
Oct 9 2005, 12:23 PM
Here's a pic of a similar muffler but for 1.7/1.8. See how the flange is right up against the muffler and the brace is much shorter? Also not the S curve at the rear of the HEs. The 2.0 goes straight back, so you can see why the flange would end up farther from the muffler.
jimkelly |
Oct 9 2005, 12:46 PM
I'm convinced the muffler in question is for 1973/74 2.0.
Thanks, Jim |
wilchek |
Oct 9 2005, 12:54 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Jim, I have a 1.7 with that similar muffler. Take a look at the pictures. If you need more let me know. In the one picture you can see how it stick out from the bottom of the rear bumper.
wilchek |
Oct 9 2005, 12:56 PM
sticking out the bottom
wilchek |
Oct 9 2005, 12:57 PM
one more
wilchek |
Oct 9 2005, 01:07 PM
last one, I think this flage is closer than the one u are looking at, good luck
Header Side Attached image(s) |
North Bay 914 |
Oct 9 2005, 01:10 PM
Senior Member Group: Members Posts: 509 Joined: 25-January 05 Member No.: 3,504 |
I just scored this from the bay, IT ROCKS, makes my stock 2.0 think its a BIG BLOCK CHEVY ! I could not be happier...now to make a custom valance for it...
jd74914 |
Oct 9 2005, 04:35 PM
what is it?
North Bay 914 |
Oct 9 2005, 06:23 PM
Its a stock 914 muffler, with the cookie cutter mega phones welded on, and the stock tip removed. It sounds so good, I can not believe its a 4 cyl Type IV when you get on the gas.
I think I may try to make another. A friend of mine at work is a great TIG welder. |
snflupigus |
Oct 9 2005, 09:41 PM
Member Group: Members Posts: 320 Joined: 29-May 05 From: Gilbert, AZ Member No.: 4,163 Region Association: None |
sound clip?
how loud is a stock 2.0 with glasspacked megaphones straight out? I've been thinking of running a crossed glasspack setup sort of like the original 69 camaro's had optional? Anybody know what I'm talking about? ok... here is what I'm talking about... (IMG:http://www.snflupigus.com/pics/chambered1.jpg) (IMG:http://www.snflupigus.com/pics/chambered2.jpg) I just want to know if it will be throaty and loud. I want loud. but i want throaty too.. Thanks.. |
Lo-Fi Version | Time is now: 13th May 2024 - 12:11 AM |
