Shifter idea |
Shifter idea |
spare time toys |
Oct 9 2005, 03:59 PM
Today I was looking at a sand rail mag. and they had cable shifters for mid engine sand rails for around $400. Has anyone ever looked into using one of these and adapting it to a side shift or tail shifter? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
MecGen |
Oct 9 2005, 04:21 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Did you find it on the net also ? sounds real interesting. I have on heard rumors and whispers, would like to see one up close and personal. Gotta link? Later (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Aaron Cox |
lots of work.... |
spare time toys |
Oct 9 2005, 05:36 PM
No it was just in some reading material laying around work. It looked like it would not be that hard to make work though. |
tat2dphreak |
Oct 9 2005, 06:12 PM
I think someone here adapted a cable shifter... it may have been for a 915 though (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) it's been brought up, but I dunno if anyone was successful
john rogers |
Oct 9 2005, 06:29 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Patrick motorsports in Phoenix has a setup similar to what you are looking for but they use the regular shifter on most all their race cars. I was thinking of a cable shifter but once I bought a Rennshift, sealed coupler and better bushing for the rear support there was no need. The trans shifts about as good as the one in my new mini as there is no slop or free play anywhere. Just remember it is a 35 year old design and has some limitations.
Jeroen |
Oct 9 2005, 07:09 PM
there's a company out there that sells bolt on cable shifters
they're called brandwood they used to have a website (www.brandwoodcars.com) but it's gone... |
dbledsoe |
Oct 9 2005, 07:28 PM
Mutineer Group: Members Posts: 300 Joined: 13-May 03 From: Boise, ID. Member No.: 687 |
John, Can you elaborate on the sealed coupler and better bushings for the rear support? Are these different than the standard 914 couple and rear support bushing, and if so where can one buy them? As a part of my Buick V6 conversion in my 75 side shift I replaced every bushing in the shift linkage system with new OEM Porsche stuff and the shifting is still about as sloppy as it was before. I'm considering the Renn shifter but if there are other things like the sealed coupler and rear support you speak of that are better than the OEM stuff I'd like to give that a try. Thanks, Don |
Brett W |
Oct 9 2005, 08:27 PM
pull the shifter from an Accord. They have a really nice Shifter base. Then order some nice push pull cables from Chassis Shop. Replace the stock rubber cable ends with some solid rod ends and fab a bracket set up for the tranny end.
spare time toys |
Oct 9 2005, 08:29 PM
Jist did a search and found them. $595 for a set up for a 914. |
john rogers |
Oct 9 2005, 08:42 PM
I bought the coupler from Stomski Racing (http://www.stomskiracing.com/) and make sure you tell him it is for a 914. The firewall and rear busings I made from delrin and machined to replace the stock ones with a cover holding the firewall bushing in place. I made the rear tube section from a piece of thin walled cro-mo tubing and welded the rear section on from a stock shift rod. I thought someone here or on the Bird Board was selling the bonze bushings?
dbledsoe |
Oct 9 2005, 08:45 PM
Sounds good but a web site link where you found them would be nice. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Or is it the web site you listed (www.brandwoodcars.com)? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
spare time toys |
Oct 10 2005, 05:15 AM
The site is WWW.brandwoodcarsllc.com the phone number is 602-437-3107 |
MattR |
Oct 10 2005, 09:44 AM
How about adapting a cable shifter from a mitsubishi eclipse? I saw a writeup on it a while ago and I think the guy built it out of a junkyard and a mcmaster catalog.
andys |
Oct 10 2005, 09:53 AM
Try an MR2 shifter. There was/is one on Ebay just the other day complete with cables. $26 was the bid then. Looked very nice.
As for cables, go directly to CableCraft....oh, they are now Tuthill Corp. The local (there are several across the US) distributors can make them to any length, any bulkhead, and any end. IMO, they are better than Morse, and cheaper too. Andys |
Lo-Fi Version | Time is now: 12th May 2024 - 08:38 PM |
