spare time toys
Oct 9 2005, 03:59 PM
Today I was looking at a sand rail mag. and they had cable shifters for mid engine sand rails for around $400. Has anyone ever looked into using one of these and adapting it to a side shift or tail shifter?
MecGen
Oct 9 2005, 04:21 PM
Did you find it on the net also ? sounds real interesting.
I have on heard rumors and whispers, would like to see one up close and personal.
Gotta link?
Later
Aaron Cox
QUOTE (spare time toys @ Oct 9 2005, 02:59 PM) |
Today I was looking at a sand rail mag. and they had cable shifters for mid engine sand rails for around $400. Has anyone ever looked into using one of these and adapting it to a side shift or tail shifter? |
lots of work....
spare time toys
Oct 9 2005, 05:36 PM
QUOTE (MecGen @ Oct 9 2005, 05:21 PM) |
Did you find it on the net also ? sounds real interesting. I have on heard rumors and whispers, would like to see one up close and personal. Gotta link?
Later
No it was just in some reading material laying around work. It looked like it would not be that hard to make work though.
tat2dphreak
Oct 9 2005, 06:12 PM
I think someone here adapted a cable shifter... it may have been for a 915 though
it's been brought up, but I dunno if anyone was successful
john rogers
Oct 9 2005, 06:29 PM
Patrick motorsports in Phoenix has a setup similar to what you are looking for but they use the regular shifter on most all their race cars. I was thinking of a cable shifter but once I bought a Rennshift, sealed coupler and better bushing for the rear support there was no need. The trans shifts about as good as the one in my new mini as there is no slop or free play anywhere. Just remember it is a 35 year old design and has some limitations.
Jeroen
Oct 9 2005, 07:09 PM
there's a company out there that sells bolt on cable shifters
they're called brandwood
they used to have a website (www.brandwoodcars.com) but it's gone...
dbledsoe
Oct 9 2005, 07:28 PM
QUOTE (john rogers @ Oct 9 2005, 06:29 PM) |
Patrick motorsports in Phoenix has a setup similar to what you are looking for but they use the regular shifter on most all their race cars. I was thinking of a cable shifter but once I bought a Rennshift, sealed coupler and better bushing for the rear support there was no need. The trans shifts about as good as the one in my new mini as there is no slop or free play anywhere. Just remember it is a 35 year old design and has some limitations. |
John,
Can you elaborate on the sealed coupler and better bushings for the rear support? Are these different than the standard 914 couple and rear support bushing, and if so where can one buy them? As a part of my Buick V6 conversion in my 75 side shift I replaced every bushing in the shift linkage system with new OEM Porsche stuff and the shifting is still about as sloppy as it was before. I'm considering the Renn shifter but if there are other things like the sealed coupler and rear support you speak of that are better than the OEM stuff I'd like to give that a try.
Thanks,
Don
Brett W
Oct 9 2005, 08:27 PM
pull the shifter from an Accord. They have a really nice Shifter base. Then order some nice push pull cables from Chassis Shop. Replace the stock rubber cable ends with some solid rod ends and fab a bracket set up for the tranny end.
spare time toys
Oct 9 2005, 08:29 PM
QUOTE (Jeroen @ Oct 9 2005, 08:09 PM) |
there's a company out there that sells bolt on cable shifters they're called brandwood they used to have a website (www.brandwoodcars.com) but it's gone... |
Jist did a search and found them. $595 for a set up for a 914.
john rogers
Oct 9 2005, 08:42 PM
I bought the coupler from Stomski Racing (http://www.stomskiracing.com/) and make sure you tell him it is for a 914. The firewall and rear busings I made from delrin and machined to replace the stock ones with a cover holding the firewall bushing in place. I made the rear tube section from a piece of thin walled cro-mo tubing and welded the rear section on from a stock shift rod. I thought someone here or on the Bird Board was selling the bonze bushings?
dbledsoe
Oct 9 2005, 08:45 PM
QUOTE (spare time toys @ Oct 9 2005, 08:29 PM) |
QUOTE (Jeroen @ Oct 9 2005, 08:09 PM) | there's a company out there that sells bolt on cable shifters they're called brandwood they used to have a website (www.brandwoodcars.com) but it's gone... |
Jist did a search and found them. $595 for a set up for a 914. |
Sounds good but a web site link where you found them would be nice. Or is it the web site you listed (www.brandwoodcars.com)?
spare time toys
Oct 10 2005, 05:15 AM
QUOTE (dbledsoe @ Oct 9 2005, 09:45 PM) |
Sounds good but a web site link where you found them would be nice. Or is it the web site you listed (www.brandwoodcars.com)? |
The site is WWW.brandwoodcarsllc.com the phone number is 602-437-3107
MattR
Oct 10 2005, 09:44 AM
How about adapting a cable shifter from a mitsubishi eclipse? I saw a writeup on it a while ago and I think the guy built it out of a junkyard and a mcmaster catalog.
andys
Oct 10 2005, 09:53 AM
Try an MR2 shifter. There was/is one on Ebay just the other day complete with cables. $26 was the bid then. Looked very nice.
As for cables, go directly to CableCraft....oh, they are now Tuthill Corp. The local (there are several across the US) distributors can make them to any length, any bulkhead, and any end. IMO, they are better than Morse, and cheaper too.
Andys
