OT: 2002 Honda Civic Alternator Removal |
joea9146 |
Oct 10 2005, 08:17 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
My Daughter has a 2002 Honda Civic I believe it has a bad Alternator.
She is at college, from the pictures she has sent me it looks like the belts are still in place so I am thinking the Alternator has failed. The Battery light is flashing on the dash. Has anyone replaced one of these ? I have searched google but have not found a How to on remomoving the alternator . Looks like it is in a tight spot to access. Anyone done one of these? or Know where I might find how to remove the Alternator. Cant be any worst than a 914 Alternator... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Thanks... |
Oct 10 2005, 09:05 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
2002? Hmm... Do you know if the engine is a D-series or a B-series? It'll say on a boss down on the front of the motor by where the transmission mates to it.
On the older D-series cars (talking late 1980s and early 1990s), you can either unbolt the brake master cylinder and move it just a bit to squeeze the alternator out, or you can get the suspension into full droop and turn the alt just so to squeeze it by (after removing the plastic shrouding from the fender well), or you pass it underneath the intake manifold to the other side of the engine bay to an opening you can get it out of. Not sure if the 02 would be done the same way. --DD |
joea9146 |
Oct 10 2005, 09:14 AM
Not Sure the Civic is a 2dr coupe EX I believe it is NOT a 2.0 so not sure how that relates to the B or D series. or if that even Helps... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
McMark |
Oct 10 2005, 09:29 AM
My 93 drops right out. Doesn't look like it would, but it does. Unbolt it and see if you can wriggle it out. Mine come out through the bottom. I didn't have to unbolt anything else.
Lo-Fi Version | Time is now: 11th May 2024 - 07:03 AM |
