What size tires to buy? |
ben1440 |
Oct 10 2005, 09:32 AM
Member Group: Members Posts: 171 Joined: 1-March 05 From: Santa Rosa Ca Member No.: 3,688 |
I just got some EMPI 8 spoke wheels and i need to find tires to fit them. I am guessing it is a 15 inch wheel so am i looking for a 195/60r/15 or something like that? Any help much appreciated.
--Ben |
seanery |
Oct 10 2005, 09:35 AM
where did you get the wheels?
Are the VW offset or 914 offset? There will be a difference in tire size that will fit. IIRC, the vw offset will only allow a 165/SR 15-ish size, but with the 914 offset you can get 195/60 15s to fit. |
McMark |
Oct 10 2005, 09:37 AM
With stock wheels, a 205 will fit most stock fendered cars. I'm not sure what the EMPI back spacing is, but that will affect the size of tires. 195 should be perfectly safe.
ben1440 |
Oct 10 2005, 09:39 AM
Well i guess i need to do some more research. What can I do to figure this out?
Aaron Cox |
Oct 10 2005, 09:48 AM
pull a wheel and measure backspacing. measure from the INSIDE lip to the hub mating surface. 112mm or so.... is optimal |
Lo-Fi Version | Time is now: 9th May 2024 - 03:01 PM |
