need a new tranny??, hole??? |
grasshopper |
Oct 10 2005, 07:34 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
I found a hole in the bottom of the tranny, where it mounts to the engine block. I have a feeling this isnt supposed to be there....Would that explain why there is oil/tranny fluid all over the underbody?? Could this damage extend into the engine?? Thanks
qa1142 |
Oct 10 2005, 07:35 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
that is standard hole. You can see timing marks through it.
It lets the oil leaking from rear main seal out of the clutch. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Oct 10 2005, 07:52 PM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
that's a drain hole. originally intended to drain rainwater, now mostly used to drain oil from a leaking tranny input shaft seal or a rear main engine seal ... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Andy |
grasshopper |
Oct 10 2005, 07:59 PM
wow, thats a reief (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Thanks!!!!!!
grasshopper |
Oct 10 2005, 08:00 PM
wait......how would rainwater get in the tranny anyway??? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
jimkelly |
Oct 11 2005, 09:41 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
The tranny also has two larger holes on top of it - water could concievably get in thru these top breather holes. Jim
SLITS |
Oct 11 2005, 11:05 AM
Easily in the deep south.................... |
Lo-Fi Version | Time is now: 12th May 2024 - 02:53 AM |
