grasshopper
Oct 10 2005, 07:34 PM
I found a hole in the bottom of the tranny, where it mounts to the engine block. I have a feeling this isnt supposed to be there....Would that explain why there is oil/tranny fluid all over the underbody?? Could this damage extend into the engine?? Thanks
qa1142
Oct 10 2005, 07:35 PM
that is standard hole. You can see timing marks through it.
It lets the oil leaking from rear main seal out of the clutch.
jimkelly
Oct 11 2005, 09:41 AM
The tranny also has two larger holes on top of it - water could concievably get in thru these top breather holes. Jim
