front mounted tank questions...related to:, thermostat, inline filter, line sizes... |
DrifterJay |
Oct 13 2005, 03:22 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
ok I am most likely going to do a front mounted tank. The big one... Here are are my questions...
Can I run AN-16 lines all around? What thermostat should I run? What inline oil filter should I run What would be the running oil capacity? Assuming I am running a PMS style front mount tank... How often do u have to change the oil when you have "that" much oil...lol? I have seen a lot of guys mounting there inline oil filter in the front of the car, for instance Joe's 914 RS....Doesnt changing the oil and filter make a nasty mess of the front trunk? Why not mount the filter on the firewall, on the bottom directly underneath the fuse panel? So as to not create a mess? Is there some advantage to having it in the front? Other than the everything in one place mentality... Stupid question...what method do people use to drain their oil, esp. when using a front tank? I have no clue as to whether or not 911 motors have drain plugs? Or do u just disconnect the lowest oil line possible? Later down the road when I have more money, I intend to do some kind of purty front mount oil cooler setup, but right now, I just want to get the car driveable, as soon as I can, after getting home of course....just doing my research...BTW: I should be out of Iraq in less than a month... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Its been a long year... -Jared PS: Do any racing bodies have anything against oil lines being ran through the interior of the car? Thinking of a possible alternative to save money by making my lines shorter... |
DrifterJay |
Oct 13 2005, 04:17 PM
jhadler |
Oct 13 2005, 04:21 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Wow, -16 size lines. That's substantial.
As for running them through the passenger comaprtment? Many sanctioning bodies will balk at that. At the very least, you should build some form of "bulkhead" that prevents oil from spraying on the driver in teh event of an oil line failure (for whatever reason...). -Josh2 |
DrifterJay |
Oct 13 2005, 05:13 PM
BUMP MOTHAFUCKA! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Aaron Cox |
Oct 13 2005, 05:22 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
cooler lines are min -12 im told....
sixnotfour |
Oct 13 2005, 06:50 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
-16 if up front to the engine everything else, -12
troutman thermostat -GPR Peterson filter console fram HP filter The capacity you wont know until you fill it. and depends on the tank size. you drain the tank and there is a drain plug on the 911 motor I have a rear trunk mounted Peterson tank/filter no cooler , 14-16 Qts. I put it in the back , to be different (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) plus I use the front trunk for everything, delivery vehicle/cafe racer here is a pic, food for thouhgt , keep your head down Attached image(s) |
sixnotfour |
Oct 13 2005, 06:53 PM
easy oil check, decklid has 18 holes for the spoiler figured one more wouldnt hurt
Attached image(s) |
DrifterJay |
Oct 14 2005, 07:15 PM
bumpin it....
sixnotfour |
Oct 14 2005, 07:22 PM
MaCal thermo. with -12 100.00 ,money saver
DrifterJay |
Oct 14 2005, 07:30 PM
sixnotfor,
how many oil lines come off the engine? One most setups I see two coming to the tanks...Is there only two lines? |
sixnotfour |
Oct 14 2005, 07:59 PM
Basically yes there is only 2.
1. feeds the engine, (bottom of tank) 2. return from motor thru filter , cooler. (Top of tank) The others are breather from top of motor , and the other would be breather for the tank , to puke bottle and or air cleaner. |
Aaron Cox |
Oct 14 2005, 08:02 PM
and if jared wanted to add a cooler... that goes from the scavenge line from motor to thermostat to cooler and to tank. ?
sixnotfour |
Oct 14 2005, 08:20 PM
Yep , but is still only one line return to tank.
See Trekkor's trunk http://www.914world.com/bbs2/index.php?act=...hl=front+cooler |
Lo-Fi Version | Time is now: 17th May 2024 - 09:38 PM |
