> Today's Texas 914 Update, Diagnosed DougC's CIS ...
ClayPerrine
post Oct 13 2005, 07:44 PM
Post #21
I went over to DougC's house after work today. We did some checking on his CIS system on his 2.7S motor. Nice install. The airbox was modified using AUDI parts so that the factory engine latch could be retained.
I started with the basics. Spark was there and strong. Checked the timing by taking out #1 plug and feeling for compression, then checking to make sure that the rotor was pointed at the #1 wire. No problems there.
Pulled one injector and with the key on, raised the sensor flap. Yep.. we got fuel spray.
Put the plug back in and hooked the wire up. Put the injector back in. It fires and runs for about 30 seconds then dies. I wait 30 seconds and try again. It does it again.
It was then I noticed that the metal fuel return line under the battery was plugged with a bolt... But no fuel is leaking out.... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
I look, and the accumulator is off a later car, and there are 3 fittings on it. The return line is plumbed into the back of the accumulator, and it goes no where else.
Well..... that will make the car run a bit rich!!!!!!
Doug is going to Stuart hose on Saturday to get a new line made. It was too short from the accumulator to the fuel distributor anyway.
I came home and watched Mythbusters. I had to watch, they were firing large caliber firearms into a swimming pool to test the myth that diving into a pool will keep you from getting shot. Even a .50 caliber sniper rifle would not hurt you if you were 3 feet underwater. All of the high velocity, supersonic rounds self-destructed on impact with the water. But the solid lead 9mm pistol would hit you 9 feet under the water!!!
After the show, I got off my lazy butt and finished reassembling my six after fixing the clutch. It only took about 45 minutes, and I was able to fire it off.
Took it out and drove it around the block. All is well here.
BTW.. I am no longer a redneck..... 4 out of 5 cars that are at my house run!!! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
ClayPerrine   Today's Texas 914 Update   Oct 13 2005, 07:44 PM
spare time toys   So yours is going once more and Dougs will be goin...   Oct 13 2005, 09:02 PM
goose2     Oct 13 2005, 11:13 PM
ClayPerrine   Get Doug to take some picts and post them here. I...   Oct 14 2005, 05:52 AM
redshift   Clay, please move here. Thanks. Your buddy, Mile...   Oct 14 2005, 06:06 AM
spare time toys   http://www.914world.com/bbs2/...   Oct 14 2005, 07:10 AM
ClayPerrine     Oct 14 2005, 07:48 AM
ClayPerrine   Doug.. the Masses here want pictures of the CIS ai...   Oct 14 2005, 07:56 AM
DougC   Yep, things are looking up with my car now. Clay f...   Oct 14 2005, 08:22 AM
tat2dphreak   http://www.914world.com/bbs2/...   Oct 14 2005, 08:33 AM
ClayPerrine   Doug, After getting home last night, I did some ...   Oct 14 2005, 08:36 AM
goose2
  Oct 14 2005, 09:07 AM
DougC   Clay, my wallet liked your first recommendation <...   Oct 14 2005, 10:16 AM
ClayPerrine   Probably a generic picture. This is a link to the ...   Oct 14 2005, 10:34 AM
DougC   Well not to beat a dead horse...But... here's ...   Oct 14 2005, 12:41 PM
goose2   When I was looking for an accumulator for my 3.0 I...   Oct 14 2005, 12:41 PM
DougC   The one I just pictured ('76 model) is $6...   Oct 14 2005, 12:44 PM
DougC   Here's another thought, is there any place tha...   Oct 14 2005, 01:36 PM
ClayPerrine   If you can find the correct sized cap it should be...   Oct 14 2005, 02:25 PM
DougC   OK, I was able to locate the correct size cap nut ...   Oct 17 2005, 08:34 AM
DougC   And I had a hose made up for the fuel return to th...   Oct 17 2005, 08:37 AM
DougC   The problem is, that the car is still doing what i...   Oct 17 2005, 08:45 AM
DougC   another..   Oct 17 2005, 08:45 AM
DougC   ...and one more. Doug C   Oct 17 2005, 08:46 AM
jr91472   Lookin good Doug! http://...   Oct 17 2005, 09:06 AM
DougC   I feel so close..yet so far. Here's a pic of t...   Oct 17 2005, 09:25 AM
goose2   http://www.914world.com/bbs2/...   Oct 17 2005, 09:44 AM
DougC   Thanks Randy, I don't know any of the specific...   Oct 17 2005, 10:15 AM
Ferg   Nice Doug, Since i'm familer with that motor ...   Oct 17 2005, 10:35 AM
DougC   Thanks - I'll have to make note of that. Dou...   Oct 17 2005, 10:53 AM
ClayPerrine   Doug... things have been a little hectic around he...   Oct 17 2005, 11:56 AM
DougC   Yes, Clay I know how hectic it can get so no prob ...   Oct 17 2005, 12:54 PM
JOHNMAN   Did you get it running yet?   Oct 22 2005, 12:19 PM
ClayPerrine   I went over to Doug's yesterday morning. I di...   Oct 24 2005, 09:01 AM
DougC   Many thanks to everyone who have helped me with ge...   Oct 24 2005, 09:26 AM
Ferg   http://www.914world.com/bbs2/...   Oct 24 2005, 09:30 AM
- Lo-Fi Version Time is now: 26th November 2026 - 10:31 AM
