Anybody have a CAD file of the dash face? |
Aaron Cox |
Oct 14 2005, 12:27 PM
title says it all.
would like to make a one piece dash face. with a DIN radio slot. and no seatbelt warning light. AA |
Demick |
Oct 14 2005, 12:33 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Damn. Exactly what I did a few months ago. I should have made a template!
It's easy to do though. The basketweave is glued to a piece of metal that is stuck to the dash face with double stick tape. Just remove that piece of metal and you have your template. The only thing you have to do is add the radio plate portion. Demick |
Qarl |
Oct 14 2005, 12:41 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I want one too. Exactly as you described. Aaron, let me know what you discover.
Aaron Cox |
Oct 14 2005, 12:56 PM
i have a cardboard template from rhodyguy......
but id like to make something.... with AID of a CAD file |
McMark |
Oct 14 2005, 01:18 PM
I've been looking for a radio plate to CAD for months now.
(IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Grimstead |
Oct 14 2005, 01:22 PM
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
Hey, I could use that too.... |
Aaron Cox |
the 3 piece OE dash metal is stupid. i want a ONE piece, that has both column pieces and a radiio plate into one common piece..... |
Allan |
Oct 14 2005, 01:48 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Demick |
Oct 14 2005, 01:50 PM
One problem you will run into in trying to make the pieces that fit to the left and right of the steering column out of a single piece - in order to install the piece, it needs to bend at that intersection pretty severely. So unless your dash face material that you plan to use is pretty flexible, you will have a problem. When I did my CF dash face, I originally had one piece, but ended up cutting a small gap right over the steering column in order to install it.
Demick |
Aaron Cox |
Oct 14 2005, 01:55 PM
i pull the column cover to install.... |
MattR |
Oct 14 2005, 02:08 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Bonehead, I made one months ago. I just need to test it in lexan on our CNC Router at work but we moved shops and have been busy as hell.
I got ya'll covered, I just need to test it first to check fit. |
Aaron Cox |
Oct 14 2005, 02:11 PM
DOh! i forgot. make it so chief. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
horizontally-opposed |
Oct 14 2005, 02:16 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
McMark!
I've got a perfect radio plate you can borrow anytime! pete |
McMark |
Oct 14 2005, 06:55 PM
FINALLY! PM coming your way Pete.
Qarl |
Oct 14 2005, 07:19 PM
I'd still like a CAD file.
TonyAKAVW |
Oct 14 2005, 07:23 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Cool! I was just thinking about this today. Except I think I'm going to make mine with the radio mounted closer to the steering wheel, and deleting the heater controls. Also going to use different switches, so it will be pretty different than stock.
Another thought I had... Instead of using those speaker pods by the door, how about mounting a pair of these in the dash face? They are 2 inch diameter drivers that undoubtedly have no bass, but that can be fixed by a small subwoofer mounted somewhere else. Definitely not a stock look, and you'd have to be creative to find the space.... -Tony Attached image(s) |
TonyAKAVW |
Oct 14 2005, 07:27 PM
Or these... not quite as flashy..
Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:41 PM |
