1.7L Oil cooling AGAIN!, Deep sump,O/C block,hoses go ? |
Cap'n Krusty |
Oct 17 2005, 03:28 PM
Gee, I wonder what the "in" and "out" embossed on the filter adapter mean? ............................................ Bet they're on the adapter on the filter console, too. The Cap'n |
Brotherbob |
Oct 17 2005, 03:35 PM
Lazy Hack Group: Members Posts: 152 Joined: 6-September 05 From: Granbury TX Member No.: 4,756 |
Oh gee thanks Capt Crusty for ruining my buzz....mannnn!
I was wondering about the sump , maybe returning oil or scavaging oil from here had a benifit? (IMG:http://www.914world.com/bbs2/html/emoticons/alfred.gif) |
Aaron Cox |
Oct 17 2005, 03:37 PM
unless you have a turbo or 2 that needs to drain back into the sump... just plug em. |
Oct 17 2005, 05:09 PM
Check the level of the oil with regard to the level of the heads. The heads are significantly higher than the highest level of oil you'll ever run... If you put enough oil in it to fill the heads, the crank will be smashing into the oil pool and the motor probably won't even run!
It's easier to run the lines in the cockpit, because they're out of the way of the wheels, suspension parts, other moving bits of the car. Running the lines under the car exposes them to road hazards--so one speed bump could kill your engine dead, which is not a happy thought. --DD |
Brotherbob |
Oct 18 2005, 03:44 PM
Sump ports plugged. Still think a external cooler with fan and switch seems to be the way to go. I also like the hoses running beside the longs.
Thanks for the help and education ,this board rocks. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
Aaron Cox |
Oct 18 2005, 04:26 PM
you can use both! use a mocal thermostatic sandwich plate which allows you to run lines to the front of the car and run an AUXILLARY cooler...with a built in thermostat. AA |
Lo-Fi Version | Time is now: 17th May 2024 - 03:08 PM |
