First Gear Syncro and Dogtooth pics |
JoeSharp |
Oct 17 2005, 09:27 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I took these pics because Las Vages Steve and I had a conversation about it.
First gear hub and syncro. What I'm looking for is the angle of the inteface between the syncro hub and the syncro band. Attached image(s) |
JoeSharp |
Oct 17 2005, 09:29 PM
The ware aera is close to the split in the syncro band. As you can see the teeth match to the band.
JoeSharp |
Oct 17 2005, 09:32 PM
The other side
JoeSharp |
Oct 17 2005, 09:39 PM
In order for first gear to be engaged, the syncro has to go into the slider at least 6mm or about 1/4"
:PERMAGRIN: Joe Attached image(s) |
JoeSharp |
Oct 17 2005, 09:44 PM
Steve had mentioned to me that he had a problem going into first gear and that the shifter felt that it was blocked going into first gear.
:PERMAGRIN: Joe |
LvSteveH |
Oct 17 2005, 11:28 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Nice pics Joe. Just for those who are wondering, I used a new first gear synchro/sider/dogteeth, and am having fussy 1st gear engagement.
The problem occurs when I'm at a stop light, out of gear, light turns, depress clutch, go for 1st gear. Half the time it goes in nice and smooth, the other have you have to re-clutch and pray. When it doesn't go, it's like hitting a wall, no indication of engagement. The clutch is properly adjusted and the 1st/reverse stack is not spinning as indicated by being able to go into non-synchronized reverse repeatedly with no issues. There is never any grinding, it's just hitting a wall trying to get into 1st about half the time. All new shift bushings of course. The only thing I can think of is that I'm getting some kind of binding of the slider as it engages the synchro. I don't have enough miles on it to know if it will get better with time. Joe was wondering if adding a chamfer to the slider would make initial engagement more predicable. |
Aaron Cox |
Oct 17 2005, 11:34 PM
same here. i always hit 2nd or third, then go for first...... |
Twystd1 |
Oct 18 2005, 02:11 AM
It is my job to be the harbinger of bad news..
I took the job over from Aaron last month... He couldn't take it anymore.. Oh well... Twystd1 : (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
Joe Ricard |
Oct 18 2005, 04:52 AM
Those are some nice looking gear parts ya got there.
I only dressed up my 1st gear parts with a sharpening stone. no burrs etc. new synchro band. I get into gear about 95% of the time. Too much force just makes it worser. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Red-Beard |
Oct 18 2005, 07:05 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
You need to clean up the ridges inside the slots in the slider.
fatlando |
Oct 18 2005, 08:51 AM
Member Group: Members Posts: 259 Joined: 6-September 04 From: imperial beach, california Member No.: 2,700 |
Are we stuck with these 901 thangs???
If money wasn't an issue couldn't machine shop build a better current one?? I'm just sore cuz mine is in pieces at the moment and have had no time to work on it.... plus driving the wifes neon sux! |
DBCooper |
Oct 18 2005, 09:35 AM
She already knew that and is probably laughing her ass off to hear you say it. ...so what kind of new car are you going to get her? (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
olav |
Oct 18 2005, 09:47 AM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
The main reason for the "clunk" when slaming it into first gear at a stop light is because only the very tip of the synchro is used for first (when egaging from stop) because of the break band. The break band stops first from rotating after about 1/8 of a rotation. The synchro engages firt gear and the brake band rotates as it rotates the band expands and stops the first gear dog teeth. At that point the slider engages and their respective positions aren't matched. Basically, there isn't enough time for first to spin up and it gets shut down by the break band. When they aren't matched there is a "clunk" Only first gear has a break band. When you change from second to first you aren't allowing the break band to engage and the syncro is doing it's job of spinnig up first to the same speed as second (via the slider) and it goes in nicely. |
aircooledboy |
Oct 18 2005, 10:52 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
It ain't just first gear, and it ain't just worn parts boys. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
I'm driving my V8 w/ a tall geared 901. My 1st gear is your 2nd gear (I just don't use first), and my trany was just rebuilt top to bottom by the world famous Brad Meyuer. I have the exact same issue. Probably 4 outta 10 times, at a stop, trying to put it into gear is like hitting a wall. Going to 3rd first, then to 2nd works about 1/2 the time, but I just discovered in the last few days that reverse then 2nd seems to work every time. What the cause is, I gots no freakin idear? (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
lapuwali |
Oct 18 2005, 11:15 AM
No. ALL of the gears have brake bands, and 1st only has ONE, where 2nd, 3rd, and 4th have TWO. One can only downshift into first, so first only needs to be "sped up". 2nd through 4th can be upshifted or downshifted into, so they need to be able to be sped up or slowed down. 5th can only be upshifted into, so it only needs to be slowed down. |
olav |
Oct 18 2005, 11:30 AM
Ok, I knew first only had something unique about the break band but I couldn't quite remember. So, I'm glad someone else set it straight for the record. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
LvSteveH |
Nov 8 2005, 11:48 AM
Just thought I'd update, I now have around 2000 miles on the new first gear slider and synchro, and it is getting much better going into 1st gear the first time. It will still block it out once in a while, but now you can pull it in without reclutching. I think it's just a stiff synchro binding with the slider, and with time the synchro wears a bit and becomes more compliant.
Bleyseng |
Nov 8 2005, 03:08 PM
This is typical with brand new parts as they have to wear in some! |
Lo-Fi Version | Time is now: 18th May 2024 - 11:13 AM |
