3 Pages V < 1 2 3
> -6 Original Motor Convert?
brant
post Aug 14 2003, 12:56 PM
Post #41
You probably need to decide which of those classes you ultimately want to be in and then decide the case issue from there.
5 bolts...
A whole nother can of worms.
I like em and both of my cars are 5 bolt.
however, they are not necessary.
the argument is that it gives you more wheel choices.
I would add that its largely cosmetic.. but does look good and fits with a -6
braking wise.... its debateable that this is necessary.
It could be argued that the vented weight.. actually slows you down and brakes are not the most important aspect of a 100 - 120hp car.
vented rotors can be added to 4 bolt
lots of options/ just not a necessity.
and remember I like 5 -bolts.
Kinda like the motor question.. it comes down to budget.
brant
post Aug 14 2003, 02:01 PM
Post #42
I definitely want to go with the 2.0 class. More competition by far.
The brakes question is important to me, and the only reason i would want to go 5 lug is for the wider brake options that come with it. Larger calipers and rotors are needed when you start going faster (or at least have the ability to).
Was not aware that there was a vented rotor available for the stock setup though....
post Aug 14 2003, 02:06 PM
Post #43
UPDATE ON THE CASE ON EBAY:
Case #: 901.101.101.OR
Mean anything in terms of date? I have zero clue....
seanery
post Aug 14 2003, 02:36 PM
Post #44
waiting to rebuild whitey!
I would say it IS and early replacement case.
but that's an educated guess.
J P Stein
post Aug 14 2003, 02:47 PM
Post #45
Irrelevant old fart
914/6s came with an aluminum case, IIRC.....a 68/96 T motor.
The case on Evilbay is one of those....
What's all the to-do about? It's a stock case and thus certainly should be legal for the vintage classes.
Their easy to spot as they are the only ones with the cooling (strengthing?) fins on the bottom.
I met a fella that runs a 914 vintage car with a 2.5L motor built on one of these cases.
Jim Chamber's ex gray car has one also.
90 mm p/cs on a 66 mm crank. There is a LARGE advantage in using Nikasil cyls on any motor.....mo hp & cooling.
seanery
post Aug 14 2003, 02:57 PM
Post #46
JP, I think the 914-6's had the 69T motor, which was magnesium.
elmonte
post Aug 14 2003, 03:01 PM
Post #47
QUOTE(seanery @ Aug 14 2003, 01:57 PM)
This is true. I have 901/38 series, It is a mag case,wish it was alum. so it would not leak as much!!
J P Stein
post Aug 14 2003, 03:09 PM
Post #48
Irrelevant old fart
It wouldn't be the first time I've recalled incorrectly (IMG:style_emoticons/default/confused24.gif)
From the stand point of vintage legality, they would be acceptable as they are pre 69 casting mold....regardless of when they were actually made....the casting # is the key.
brant
post Aug 14 2003, 05:09 PM
Post #49
BRAKES, 5 bolt set ups:
an A or S caliper is an easy conversion.
figure maybe a grand for a complete conversion.
there are bigger combinations out there but below 140hp it may not be necessary. (You can actually get a stock brake set up to handle great on the track and the fastest 914/4 -200hp I know of only runs S calipers with huge slicks and hundreds of pounds of down force)
what specifics do you want to know.
brant
post Aug 15 2003, 09:50 AM
Post #50
im relatively familiar with the upgrade posibilities available for 5 lug, and to date have been pretty impressed with my stock setup (19mm upgrade) and the right pads for what im doing. I can brake later than most other cars in my advanced run group (im going slower too) (IMG:style_emoticons/default/wink.gif)
What are the advantages of going with a stock oil tank? Why not get a remote tank (ala circle track style) and mount up front where my gas tank used to be? Is there anything inherently better about the stock location and tank?
seanery
post Aug 15 2003, 10:09 AM
Post #51
The only benefit IMHO is that the stock unit's plumbing is already figured out.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 3rd July 2025 - 09:59 PM
