Help Please.....where to power-up pump, FI to Carb Conv....Fuel pump change |
wheelo |
Oct 22 2005, 11:32 AM
Dude Group: Members Posts: 265 Joined: 19-March 04 From: San Rafael, Ca Member No.: 1,818 |
Help , please...
Anyone have advise on how to wire-in rotary fuel pump? I am doing an FI to Carb conversion, and will be switching-out stock Fuel pump. With the harness/ecu unplugged, how do you get 12v to the pump without rewire? The fuel pump relay will not be energized. I had relocted stock pump under gas tank, should I place new one there, or in engine conpartment? Any help/input appreciated as I am beginning job !! (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) - M |
TC/914 |
Oct 22 2005, 12:04 PM
Member Group: Members Posts: 203 Joined: 21-October 04 From: Southern MA Member No.: 2,981 |
The electric pump will need to be as close to the tank as possible and below the tank if you can. That pump is a "pusher" and works best in that location.
Trace the original wiring to the 12 volt key-on feed and wire it in there. Best and safest is to stick as close to stock as possible. Luck! TC |
wheelo |
Oct 22 2005, 12:27 PM
Thanks Bro !
That should do the trick .... I was stuck... and need a direction to go .... Cheers (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) - M |
Oct 22 2005, 03:41 PM
It's a Good Thing to use a relay to run the pump. The stock fuel pump relay can be used, if you ground one of the pins in the four-pin connector on the relay board. This assumes you have run the original fuel pump wire up to the front compartment (or have a 75-76, which has the wire going up front).
There have been posts about this, one in the past few days. A search will turn up some photos and at least one or two threads on the subject. --DD |
Trekkor |
Oct 22 2005, 06:58 PM
Here:
lapuwali |
Oct 22 2005, 07:29 PM
Except, Trekkor, that place on the relay board doesn't go through the fuel pump relay. I *may* go through the main relay. Two of the pins on that connector should be bridged together for the fuel pump relay to work as stock. Pins I and III, if connected together will turn on the fuel pump with the key, but through the fuel pump relay, and using the fuel pump fuse (the 8 amp one).
grasshopper |
Oct 22 2005, 07:41 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
FI to Carbs??? why??? there are no advantages at all for that.... I'm in the process of changing my car back to FI (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Oct 22 2005, 08:18 PM
all your answers are in the "classic threads" section ... right here: http://www.914world.com/bbs2/index.php?act=...=ST&f=5&t=25954 (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Lo-Fi Version | Time is now: 15th May 2024 - 12:06 PM |
