wiring harness, what are these?? |
grasshopper |
Oct 22 2005, 06:34 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
ok, changing out harnesses, when i was pulling the old one, i found this shoved behind the foam padding on front of the passenger side floor. What was it for??
grasshopper |
Oct 22 2005, 06:36 PM
got the rear half of the new harness installed, and found this and the other one in the next pic...they look like they come from the rear, what are they and where do they go??? Thanks
grasshopper |
and this??
Aaron Cox |
Oct 22 2005, 06:39 PM
top pic = EGR counter for 76 cars.
middle pic may be for the backpad light? or the handbrake light switch. now...hijack. (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) etnies sandals.... lose em. most comfortable sandals in history... i rock em 360.125 days a year. best in the world....a socal tradition |
Qarl |
Oct 22 2005, 06:40 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
First one is probably for the EGR counter (for CA cars)
Second one looks like the Rear Window defroster wires (for the rear window with the integrated wire defroster) |
grasshopper |
Oct 22 2005, 07:44 PM
Thanks guys. still dont know what the last one is though... anyone??? andy??
Aaron Cox |
Oct 22 2005, 07:45 PM
is the last one the starter hookup? |
Oct 22 2005, 07:58 PM
Does look "kinda" like the "flag terminals" that go on the aft end of the yellow starter wire. But if I am interpreting the photo correctly, the red wire has the flag-type terminal and the yellow has either a straight-on spade lug or a ring--can't tell from the pic very well.
Is that last one part of the main wiring harness, or a separate harness? What's on the other end? --DD |
grasshopper |
Oct 22 2005, 08:00 PM
it ties in to the main harness.... the yellow and red both have flag type connectors.....
Oct 23 2005, 12:31 PM
Thoughie... Looks like it connects up under the dash somewhere--the other wires sticking out of the harness are a red/white (switched power) and a brown with a ring terminal on it (ground). Maybe something to do with the headlights?
--DD |
Qarl |
Oct 23 2005, 12:47 PM
fog lights at the switch?
Or something for the center console gauges? |
snflupigus |
Oct 23 2005, 01:01 PM
Member Group: Members Posts: 320 Joined: 29-May 05 From: Gilbert, AZ Member No.: 4,163 Region Association: None |
I have a theory that vice grips sneak into just about 23.3 percent of all 914 pictures.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
JoeSharp |
Oct 23 2005, 02:50 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Berry: Why are you droping stuff on your toes?????
:PERMAGRIN: Joe |
michelko |
Oct 23 2005, 02:53 PM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
from what i can see ... i think it is connected to the combination relay. You should find it at the fuse board:
#27 maybe you can find the other end of the wires ? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) Attached thumbnail(s) |
michelko |
Oct 23 2005, 02:54 PM
this silver cube
bd1308 |
Oct 23 2005, 04:40 PM
i'm going to go with my gut feeling:
blinker relay b |
grasshopper |
Oct 23 2005, 08:01 PM
well.... thanks..... but i'm more confused now (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I'll start tracing it back tomorrow after school
grasshopper |
Oct 23 2005, 08:02 PM
dont make fun of my toes!!! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) im clumsy (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)..... i get it from my mom (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Verruckt |
Oct 23 2005, 08:46 PM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
and sandals into .5% of pictures (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
ClayPerrine |
Oct 24 2005, 09:11 AM
That's the latching relay to switch from low to high beams. If you are trying to put a 911 column in, you have to remove it. The headlight switch in the 911 does that function.... |
Lo-Fi Version | Time is now: 16th May 2024 - 03:00 AM |
