Front targa Top Seal Question ??, Are there two seals in the windshield? |
vesnyder |
Oct 24 2005, 10:08 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am in the process of putting the 914 back together and have rubber seals all over the place and of course I am trying to figure out where they all go. The one I cannot seem to find is the one (if it exists?) that goes on the top of the windshield frame that would seal the targa top? I put the bottom seal on here, but it seems like there would be one that goes above the other? Does this seal exist? Pics?
The reason I assume this seal exists is the Targa top does not seal tight on the front (or on the rear either?) and there is no tension on the latches to keep them closed. I assume this seal would do that? HELP? |
SLITS |
Oct 24 2005, 10:48 AM
There is the "C" shaped seal that goes around the windshield pillars and across the very top and there is a seal that fits in the upper channel between the pillars.
Yes, there are two............... "S" and "R" in the image (IMG:http://www.pelicanparts.com/catalog/images/WeatherStrip/914_seals2.jpg) And yes, the other is available....need one? |
vesnyder |
Oct 24 2005, 11:54 AM
It must be "S" - I iwll have to take a look. I am pretty sure I have that!
SLITS |
Oct 24 2005, 12:00 PM
The "S" is a one piece seal that looks like a "C".....seals the vent wing window and the very top of the targa against the windshield frame. A pain in the ass to install.....about $215? from parts houses The second seal actually only seals the front of the targa top against the lower part of the windshield frame...'bout 1" below the other. It is a straight, with a notch in the middle....about $65 from parts houses. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:47 AM |
