clutch problems... |
Mueller |
Feb 10 2003, 04:28 PM
installed new clutch cable...
on the transmission side of the cable, the nut is at the maximum threaded portion (tightened as far as possible) yet I could not get the clutch to release when pushing the pedal...so, I added a 1 inch spacer between the nut and the clutch fork... now the clutch will desingage but it feels odd when pressing the pedal... when I push the pedal I cannot feel any thing loose inside the tunnel to signify a loose clutch tube cable... what am I missing? I thought that if the clutch tube was broken that I would be able to feel it being loose inside the tunnel (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/blink.gif) Thanks Mike |
Lo-Fi Version | Time is now: 20th May 2024 - 04:03 AM |
