| michelko |
Nov 16 2005, 11:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
purchased already a set of new wheel bearings. This weekend i willl check/replace the ball joints.
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| Brotherbob |
Nov 16 2005, 11:36 AM
Lazy Hack ![]() ![]() Group: Members Posts: 152 Joined: 6-September 05 From: Granbury TX Member No.: 4,756 |
I would mount the rear tires on the front and front on the rear and drive it.
Nothing changes nothing lost , no money spent? Then start throwing around parts money, wheel bearings, ball joints, etc. my 2 centavos. |
| michelko |
Nov 17 2005, 06:13 AM
I have this shaky feeling since i bought the car. It was fitted with 41/2" Steel Wheels with gigantic 165 winter-Tires, now 51/2 wheels with 185 summer-tires : no change (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) totaly shot boge shocks allaround, now new koni: no change (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) rusted through hell hole and rocker, now complete solid tub: no change (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) old standard tie rods, now new turbo-tie rods: no change (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) different toe in settings tested: no change (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Things to check or change: Ball-joints wheel bearings A-Arm bushings Will do this next weekend (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| Bill Kohnke |
Nov 17 2005, 06:56 AM
Newbie ![]() Group: Members Posts: 4 Joined: 16-November 05 From: Montrose, PA Member No.: 5,137 |
Is the car a 1970?
I chased what I thought was a caster shimmy for months. It was at 50 to 55 mph. And some shaking also. This was after moving up to 205/50 tires. I finally changed out the front struts and ball joints to a 74 models. The hubcentric feature fixed the problem. Bill Kohnke |
| MecGen |
Nov 17 2005, 07:17 AM
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hey hey
Lots of good advice here...I have personaly seen an early 914 lower ball joint wobble in its socket.... My 914 had a bitch of a "sideways" wobble after hitting a railway track at an angle...my new Koni's diddn't fit quite right in the tube or loose in its own insert, 6 and 12 oclock movement when the car was jacked and shock fully extended. Switching to Boge fixed this. in the ass end my trailing arm bushings were OK but took them apart anyways...good thing, my near pearfect car had rust on the inside shafts so deep the rubber bushing where just being squished around... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) These 2 things made all the differents in the car, very hard to check and find. Ich liebe Ihr Auto (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) Later (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
| michelko |
Nov 17 2005, 11:52 AM
Yes it is a 1970 car. I am looking for a 5 lug conversion. Only missing parts are new break calipers. Don´t know if try first with new ball joints or buy new 911 calipers and 2 more fuchs and do the five lug now (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) ball joints are cheaper. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) BTW Thanks for all the good advices. I love the Club! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| brp914 |
Nov 17 2005, 11:39 PM
Unregistered |
My '70 had the exact symptom yours has, and just like everyone here has mentioned, the ball joint was loose in the strut. New later style struts using the wedge pin solved the problem. But I wanted to mention a couple things that I've read here that I disagree with. First, I cant believe the problem is in the tub. After the work you did restoring it, you probably the most solid tub on the planet. Second, people have suggested tightening the wheel bearings as a means of removing play. I think that is dangerous. Front bearings are tightened to 1 ft-lb (please do the N-m conversion). If they are still loose then the bearings and/or spindle is worn and should be replaced. Overtightening the bearings risks disaster. Feel for a groove on the under side of the spindle. good luck
| michelko |
Nov 28 2005, 01:22 AM
Hi everybody,
thhis weekend i did some improvements on the front suspension. I changend the ball joints and the wheel bearings. As they looked, they were the first ones. Original mounted in Stuttgart (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Opening the nuts that hold the ball joints was areal disaster (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) With the right tool an an impact wrench a 1/2 hour of work.... nothing happened. Weapons of choice: Attached image(s)
| michelko |
Nov 28 2005, 01:24 AM
then i decided to grind out the big nuts with a dremel. Fortunately i bought a set of that stupid nuts time ago.
| michelko |
Nov 28 2005, 01:28 AM
old stuff
| michelko |
Nov 28 2005, 01:29 AM
and the new ones
| michelko |
driver side
| michelko |
Nov 28 2005, 01:30 AM
and after half an hour of grinding
| michelko |
Nov 28 2005, 01:31 AM
the new one in
| michelko |
Nov 28 2005, 01:36 AM
after a short testdrive i decided to change the wheel bearings also.
Unfortunately no pics of that work. The shaky was a mix of a bunch of worn parts. Every step (Tierods, Ball joints, wheel bearings) made cured the shaky a little more. Couldn´t do extensive test driving because of snow (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) but till now this is an complete different car now. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| maf914 |
Nov 28 2005, 08:09 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Where did you get the tool for removing the ball joint nut? I think this is the first time I have seen the "special" tool, other than in my Haynes manual. I remember the one Dave Hunt made up from pipe fittings. I used an adjustable pipe wrench to remove them on my car. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
| michelko |
Nov 28 2005, 08:32 AM
i bought it from guy that is remanufacturing several parts, like tools, suspension bearings, caster shims, etc. I bought it before i saw the idea with the pipe fittings, on the other side 20 Euro are not to much for this rare tool Also on german ebay those tools appear from time to time. Unfortunately in my case the tool doesn´t help anything to remove the nuts. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) For torquing down the new nuts it was very helpfull. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| Aaron Cox |
Nov 28 2005, 10:44 AM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
where do you get your parts? do you go down to mittelmotor?
| michelko |
Nov 28 2005, 12:45 PM
Yes sometimes. But i have some .. lets say not so good experiences with them. So i try to find my stuff at other dealers. There is one called "914 Ersatzteile Versand". Only the best experiences, ultra fast shipping, good prices. Some parts are direct from Porsche. In Mannheim, 30km away there is an porsche agency. Ebay is also a good source for new and almost used parts. It´s in the mix. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
| michelko |
Mar 24 2006, 05:12 AM
Hi guys,
think i found the problem. excesive low ride! There are some rubber pieces mounted n the struts. there was to less room for the strut to move free if i hit a little larger bump. I turned the spindels higher an made a test drive. Nearly now shaky anymore (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif) But now the car looks like a stork (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Maybe the rubber things can be cut a little? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 2nd May 2026 - 04:24 AM |
