Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Dammit! It runs great on 2 cylinders!!! Except for the occasional backfire. 1 and 3 fire, 2 and 4 do not.
I dunno. I pulled all of the injectors and fuel lines in the engine bay. They're all clear. I have 29 pounds of fuel pressure. I tested all of the injectors while cranking the engine over. All squirt fuel in a nice conical pattern and the volume appears to be the same. I have spark on all cylinders. But only 1 and 3 fire. If I pull the injector connector or the plug wire off of cylinders 2 or 4, nothing changes. They are both not doing anything. If I pull either the injector connector or the plug wire from cylinders 1 or 3, the engine dies; apparently it can't run on just one cylinder, go figure. I'm wide open to suggestions. I need a 914 fix before the weather turns to crap. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Update! If you read all of this thread, you'll see that bondo spotted my error. I swapped wires on the dizzy for cylinders 2 and 4 and she fired right up on all four cylinders. |
TINCAN914 |
Summer's Commin... ![]() ![]() ![]() ![]() Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains ![]() |
Ok I got the fix...
Get a pen and paper, write this down, or print it out if you like. Box it up it's no good send it to me, I in return will send you mine. Hell I will even include the jack stands... Sorry Man, couldn't resist.. Wish I could help.... Good luck... |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Gint...valves on 2 & 4 too tight (1st guess).... that was the problem with Toast's car on one cylinder.. pull plug wire or injector connector no change in engine. Once I adjusted the valves (and purposely 0.001" looser), the engine no longer had a misfire.
So sayeth Ssssssslits |
Gint |
I can check it, but I just did an adjustment less than a hundred miles ago. New plugs/cap/rotor/condensor/fuel and air filters with only a couple hundred miles that all worked great before the fuel pump quit last month. The only thing I haven't done is installed my new plug wires or swapped out plugs. I verified spark at the plug end of the wires though, and as I said, the plugs only have a couple hundred miles on them. |
onrails |
if the world didn't suck,,we would all fall off ![]() ![]() Group: Members Posts: 118 Joined: 21-July 03 From: tulsa,ok Member No.: 929 ![]() |
f.i. trigger points? they fire two at a time. mabe intermitentif fluid soaked.
only other guess is a valve adjustment. my cent & a-half Brian |
Brian_Boss |
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 ![]() |
I would pull the spark plugs on the non firing cylinders and see if they are wet with fuel. It would also be interesting to swap the injector plugs (1 & 2) and (3 & 4) and see if the dead cylinder follows the injector connection or stays the same.
If spark plugs are wet with fuel and/or the miss doesn't change with the injector plug, I would think ignition and check the dead cylinders w/ a timing light. I know you're pretty knowledgeable so don't be insulted if this sounds too basic. Edit: I see you checked spark - was that with the plugs out or by using timing light or similar means to check for spark under compression? |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Is there any chance the plug wires got swapped between when it last ran and now? Easy thing to check.
Gint |
I did that already (injector connector swap). No change. That's what prompted me to pull the injectors. Like I said, checked the pattern and verified that they are all functional. I put new injector seals in while I was there. Verified spark at the spark plug ends of all of the plug wires. |
Gint |
The plug wires were completely off the cap. I pulled the dizzy and took it apart to clean it all out. It's in excellent condition as are the trigger points. I verified the firing order and plug wire locations several times. 1-4-3-2 counter clockwise on the cap, left bank 1 and 2 from the rear, right bank 3 and 4 from the rear. I have it memorized. |
Gint |
Pulled the wires at the plug end and checked them for spark against ground. And ofcourse with me as the ground (I hate doing that). (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
SLITS |
You got me....you said you have fuel to the injectors (so it's not a harness electrical or trigger point problem) and you have spark (not electrical).....and it backfires occasionaly...what's left?
closed gap on the plugs to open a gap on the plugs brigded gap on the plugs dead plugs crossed wires valves |
Gint |
I'm off with the fam to the Nuggets game. Keep those suggestions coming gang! I'm going through and verifying a thought process if nothing else.
Gint |
My thoughts too (except for the crossed wires - verified that already). I'll go after a plug swap and valve adjustment check tomorrow. |
bondo |
Umm... my engine has it 1-4-3-2 CLOCKWISE on the cap, looking from the top of the cap. methinks this is a clue to your problem.. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
been there done that!!! LOL 1 4 3 2 and only one and 3 fire. swap plugs on 2 and 4 (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
If you aren't dislexic(sp) about the 1432 ccw thing, then Bondo and Aaron are correct. Otherwise I would look at valve adjusement.
Good luck |
SLITS |
BINGO! Distributor rotation (and firing order) is CLOCKWISE......... |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
yep. I done that too,
(IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) but I knew better than to tell about it. |
Aaron Cox |
happens to the best of us..... (like ED and slits....) |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Mike Doe's this car have the injector resistor pack?? If yes you may have a broken wire on one of the resistors.
CCLINBTDT |
Lo-Fi Version | Time is now: 30th July 2025 - 05:32 PM |
