bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
ron.....
no. the rebuilders used a core case, which happened to be from a six. works 100% super on my 914. b |
Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
i had the same problem a few years ago. i would look again at the trigger points, real close this time.they can get screwed up inside, as well as at the electrical plug outside. they can also just not work for whatever reason.if you have another dizzy, swap it out and see if that helps. i would bet the problem is there.
another option is install carbs. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
That actually gave me a really good laugh Ron, thanks! I own 2 914's. Just because they're not on jackstands now doesn't mean they won't be by the end of the week. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Gint |
Thanks Dave. You missed a piece of the thread though. It's running again. I had the firing order backwards on the distributor resulting in 2 and 4 swapped. It's usually the little things that getchya. |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 01:31 PM |
