There sure are a lot of parts in a 901 box, Now I'm going to try to put them back in |
DNHunt |
Nov 5 2005, 08:30 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Lots and lots of parts that are hard to keep track of. And lots of cleaning.
Attached image(s) |
DNHunt |
Nov 6 2005, 12:33 PM
Shift forks, shafts and detents. I really like this part. People sure are clever.
I borrowed this pic from Royce. Thanks man. It shows the parts. The shift forks are not shown. A couple of things. The springs and balls on the right fit into a tube in the intermediate plate and you see the plug on the bottom of the transmission. They serve to center the transmission in neutral. They also prevent selection of 2 gears at once. You feel these somewhat (along with the compression of the syncro rings) when the shifter passes through neutral and especially when you select reverse. It works most of the time. I used a little all purpose grease to coat the parts as they can escape through the shift rod holes in the intermediate plate (and grease is usually good). I spent a while looking for 1 of the balls on the garage floor. The notch in the picture positions one of the shift forks. An 8mm bolt passes through the shift fork and engages this notch then threds into the other side of the shift fork. This notch is larger than the 8nn bolt so it allows the shift forlk some adjustment on the shaft. Tightening the bolt then clampd the shift fork to the shift rod. Ah, fork it, I can't explain it. Look at the pictures Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:51 AM |
