| ChrisReale |
Nov 6 2005, 08:03 PM
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
So my car decided to dump oil all over the floor of my parking space, pissing off the management. Ive spent the last two saturdays cleaning up the mess. I got around to replacing the rubber o-ring, lightly coated it in black sealent to help it stay put. New paper gasket and copper crush gaskets. Today I see it is still leaking oil. There always seems to be a drop hanging off the temp sender wire and a small puddle of oil about 4 inches in diameter right under the taco plate. Im getting tired of this. Im "pretty" sure my plate is not taco'ed, but not 100%. Any other ideas or should I just source a new plate? Oh, and I am not even using synthetic anymore, this is with dino schtuff (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
| 914werke |
Nov 6 2005, 08:05 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,649 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Chris what about just going the Billet route? (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| ChrisReale |
Nov 6 2005, 08:13 PM
is there a billet route? direct me.....
| qa1142 |
Nov 6 2005, 08:26 PM
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Chris
I finally left outer plate off. Just plate, oring, crush washers, and NO LEAKS! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) I had it up and down like 5 times before that. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) If all else fails, worth the try |
| blabla914 |
Nov 6 2005, 08:28 PM
I like primer ![]() ![]() Group: Members Posts: 330 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None
This shouldn't be tough to seal. What kind of sealant did you use? I've found anything that hardens on an o-ring doesn't help. Dow 111 high temp silicone grease works good for any o-ring. If you're having that much problem with that plate leaking I'd look for any kind of unevenness or gouges in the plate or case.
Kelly |
| johnmhudson111 |
Nov 6 2005, 10:04 PM
Member ![]() ![]() Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
I am having a similar issue with my car since I tapped it for an oil tempature sender. I wish someone would make a billet plate, I have even thought about going back to school to learn how make billet parts (the local comunity college has a course for it). I just wonder what it would be like to go back to school at 37 but, I degress. If someone ever makes a billet plate put me on the list for one. |
| Aaron Cox |
Nov 6 2005, 10:06 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
didnt mueller cad up a drawing?
all that is left is machining no? |
| johnmhudson111 |
Nov 7 2005, 12:41 AM
I found the drawing in another thread, asked if it ever got going, and then the tread was deleted. I thought it is odd that with the number of people that have trouble with these things that someone hasn't done one already. |
| Mueller |
Nov 7 2005, 08:20 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
just trying to improve the production method/time to lower the costs.... Chris, are you using new crush washers? |
| ChrisReale |
Nov 7 2005, 11:16 AM
Yes I am using new crush washers and gaskets.
| Aaron Cox |
Nov 7 2005, 11:51 AM
farm it out???? get these things on the makret mike (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| mikelsr |
Nov 7 2005, 12:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
I am 52 and taking a welding course at the local community college. Go for it. Mike |
| kobas |
Nov 10 2005, 11:21 AM
Newbie ![]() Group: Members Posts: 9 Joined: 28-March 04 From: Marietta, GA Member No.: 1,860 Region Association: South East States |
I had the same problem with leaking taco plate. Finally stopped leaking after I made a new gasket out of some rubberized high temp gasket material I bought at pep boys. The gasket material I used was thicker than the stock gasket.
| Bruce Allert |
Nov 10 2005, 06:18 PM
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Hi Kwith (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)
taco's are fer eat'n (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) I solved my leak problem... sold the dam thang. Bought a Miata. It don't leak (but I put it up on a curb on my Birthday) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) drivers rear wheel & A frame are in need of repair (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) But it don't leak (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif) ........b have a Fat Tiar (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
| lagunero |
Nov 11 2005, 05:47 PM
Donkey Member ![]() ![]() ![]() Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
Hey Chris, did you fix the leak? If so, how?
| sixnotfour |
Nov 11 2005, 05:55 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,215 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Sure made a mess in the back of my truck (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) So i sold the dam thing , (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) Next
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) |
| Mark Henry |
Nov 11 2005, 06:25 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
First the threads (6mm) are ok right? Seen many stripped...put in many heli-coils (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
I've used teflon tread sealant with good success. Just don't let much get by to the inside of the case. |
| DNHunt |
Nov 12 2005, 07:46 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Hey Jeff
I inherited that mess. It's leaked all over the floor of the woodshed. I've used hylomar on the O-ring and Loctite 518 on the plates and nuts. That seems to work for me. Once I got one sealed I try not to mess with it Dave |
| Bruce Allert |
Nov 12 2005, 09:52 AM
Jeff & Dave, I was kidding about my leaking prob. It leaked but not that bad.... sorry (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
You guys are speaking of Punkins rod knockin 2.0??? ......b |
| Cap'n Krusty |
Nov 12 2005, 10:04 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
REPEAT AFTER ME!: "Sealing surfaces with o-rings are designed to have clean, direct contact between the metal and the o-ring. Sealant used in these applications generally, if not always, leads to leakage." In the case of the "taco plate", there's an o-ring that fits into a deliberately designed gap between the case and the metal cover. The cover is held in place by 2 6mm machine screws, which are each sealed by a composite crush washer. This washer MUST be installed with the "split" side AWAY from the surface of the cover. If the "taco plate" has an oil temp sender provision, then there's a paper gasket installed under the protective plate, making it a 3 part sandwiched assembly. The copper crush washer still goes under the head of the machine screw, and still has the same orientation. One MUST assure that the threads in the crankcase are intact before assembling the cover assembly. The o-ring should be lightly oiled before installation, and thread sealant is permissable. If the threads are in any way degraded, they must be repaired to ensure the integrity of the seal. If the cover is warped or otherwise damaged, it must be repaired or replaced. Paper or composition gasket = sealant OK. Rubber or polymer o-ring = No sealant. How hard is that? The Cap'n |
Lo-Fi Version | Time is now: 2nd May 2026 - 11:20 AM |
