> cleaning my engine, and maintnence
shaggy
post Nov 6 2005, 10:55 PM
mechanic/welder/fabricator
so i dropped the engine finally
i have it out in my grage now and tomorrow ill start cleaning it up
heres my to do list as of yet, please if i missed anything chime in:
degrease engine
check valve cover gaskets
check for oil leaks (push rods mainly)
change oil filter assembly
put in new impeller(mine now has a missing fin, if any one has one and can sent it to my in az by friday please pm me)
replace timing belt(with impeller)
change fuel filter
change tranny ground strap(mine was trashed)
change fuel lines(where needed)
put clamps on intake runners
change spark plugs
clean engine bay
clean hell holes( por 15? anyone know anything about it?)
replace missing engine tin( im missing the front passenger tin now that my ac compresser is out of anyone anyone has one and can have it to az by friday please pm me)
neaten up electrical system(not replace anything)
so did i miss anything?
if so please tell me
id like to have my engine ready to go back in by next friday so im trying to control what im going to do
Trekkor
post Nov 6 2005, 11:02 PM
I do things...
Take some pics in the engine compartment for us to look at.
Just a fan belt, BTW (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ( No timing there )
KT
shaggy
post Nov 6 2005, 11:04 PM
i will tomorrow when i get home from school
is there as specific size on that fan belt and a better one than others?
Trekkor
post Nov 6 2005, 11:14 PM
I do things...
I always thought "Gates" made a nice belt.
While the engine is on the ground, replace the pushrod tube seals, adjust the valves no matter what, and use new valve cover gaskets.
Look for any suspicious vacuum hoses that need replacing.
Think about replacing the injector seals now.
all these things and the ones you mentioned are WAY easier to do with the engine out.
Good job (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
KT
shaggy
post Nov 6 2005, 11:19 PM
is that really necessary?
the top end was redone about 5 months ago or so
post Nov 6 2005, 11:22 PM
Resident German
QUOTE (shaggy @ Nov 6 2005, 10:19 PM)
if it's not leaking, leave the seals alone ...
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy
theol00
post Nov 6 2005, 11:24 PM
are you ready to run with trackmasters at Sears Point by Nov 13?????
Trekkor
post Nov 6 2005, 11:27 PM
I do things...
The way you described the motor being all oily with potential fuel line problems and other things, I got the feeling you are a new owner taking control.
KT
shaggy
post Nov 6 2005, 11:54 PM
my dad bought the car
then recently he bought brian millers restored 74 w/ a raby 2270 and 911 suspension brakes and wheels ect...
now the 72 914 is mine
the lines have been replaced its just this one 7 inch spot that needs it
"are you ready to run with trackmasters at Sears Point by Nov 13????? "
huh?
what is that?
is that the track thing at firebird a week from today?
if it is im not running it
my dad, john, flatvw is considering it
id like to but i dont have the money and im not 100% sure ill be un and running by then
what should i do about the seals keeping in mind that the top end was redone about 5 months ago?
rhodyguy
post Nov 8 2005, 12:53 PM
change the gear lube in the trans. check that the vent on the top of the trans is not plugged and ensure that it is oriented in the correct position, hanyes p.87.
k
maf914
post Nov 8 2005, 01:27 PM
Not a Guru!
Good time to clean the leaves, dust, dirt, etc. that builds up on top of the oil cooler and cylinders to improve the cooling. You'll have to remove some engine tin to do this, though.
Dave_Darling
post Nov 8 2005, 02:12 PM
914 Idiot
QUOTE (theol00 @ Nov 6 2005, 09:24 PM)
Sears Point (Infineon Raceway) near Sonoma, CA is an awful long way from Phoenix AZ. (Read the location field, dude!) I kinda doubt he's trying to get his car ready for that.
--DD
Trekkor
post Nov 8 2005, 05:14 PM
I do things...
I think Theo was asking me about the DE?
We took it PM. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Where are the pics, Shag-man?
KT
Flat VW
post Nov 8 2005, 06:47 PM
Illegal Soapbox Derby Racecar
QUOTE (trekkor @ Nov 8 2005, 03:14 PM)
KT
The scraggy one did his homework FIRST, he just headed for the garage, I expect an update soon.
I will tell him you rang,
John (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Flat VW
post Nov 8 2005, 07:21 PM
Jim got the shroud, impeller and oil cooler removed.
He then removed the oil filter console. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
It was galled up BAD. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
In the course of removing the oil filter console a threaded stud for the ofc un-threaded.
Jim plans to clean it and then re-thread it in with loctite.
Comments, questions, suggestions appreciated.
John
P.S. fotos to follow (including the carnage (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) ), camera battery charging.....
SLITS
post Nov 8 2005, 07:25 PM
"This Utah shit is HARSH!"
Run a timecert in if the threads pulled with the stud....threads in aluminum do not heal themselves. Loctite won't cure the problem.
They make a kit...drill, tap and timecerts....prolly available at a good FLAPS
Flat VW
post Nov 8 2005, 07:27 PM
QUOTE (SLITS @ Nov 8 2005, 05:25 PM)
I don't think it pulled, more un- threaded the stud as it must have hung up on the OFC console top nut while the nut was being removed.
Same advice Ron?
John (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Flat VW
post Nov 8 2005, 07:40 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
shaggy
post Nov 8 2005, 10:00 PM
i took the rest of the shrowd off and replaced the oil filter assembly
and then put it back together
there were some flaps/bellows in there and i cna figure out how they go back
i have them lined up but the passenger side wont close and i cant figure out how the spring fits back in its loaded position
(IMG:http://www.geocities.com/shaggy_nine14/engine/IMG_1770.jpg)
theres the flap on the driver side(i cant get it closed, if it does close)
(IMG:http://www.geocities.com/shaggy_nine14/engine/IMG_1771.jpg)
theres the flap that stays in place on the passenger side, just behind out of camra view there is a cut in the tin to allow air to flow through the oil cooler
(IMG:http://www.geocities.com/shaggy_nine14/engine/IMG_1772.jpg)
the screw driver is pointing to the rod that connects the driver flap to the rest of the car (sorry the driver is hard to see)
(IMG:http://www.geocities.com/shaggy_nine14/engine/IMG_1773.jpg)
theres the spring that should keep the flap down, i think. how shoud that be loaded and be sitting?
(IMG:http://www.geocities.com/shaggy_nine14/engine/IMG_1774.jpg)
theres a tab that comes off the rear postion of the housing that holds the rod in place
(IMG:http://www.geocities.com/shaggy_nine14/engine/IMG_1778.jpg)
thats something that holds the rod down. its in the passenger side vent thingie
does anyone know how thay are suppost to go together?
how does this all fit back together?
they haynes manual dosent have anything about this
and i dont know what they are called to search it
shaggy
post Nov 8 2005, 11:12 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
- Lo-Fi Version Time is now: 13th November 2026 - 10:56 PM
