| r_towle |
Nov 8 2005, 11:16 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
cant see the pics...post them here so we can see them.
| shaggy |
Nov 8 2005, 11:17 PM
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
damn geocities is down again (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
about 10 min ago they were fine... i hate geocities (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) |
| MattR |
Nov 9 2005, 12:17 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
You can upload pics to your blog and link in your posts! Its a great feature.
On the very top of the website, you see a green bar that says "home, forum, faq...blog". Click on blog then go to your blog, add an entry, and add pictures. |
| SLITS |
Nov 9 2005, 12:38 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The flappy thingy you're playing with directs air to the oil cooler and head / cylinders. In the closed position (cold engine), that flap would be in the up position, blocking off the airflow to the cooler / cylinders & head. In the warm position, the flap is in approximately that position (also when the theromostat wire fails, it fails in the open position you see in the pic). There is a small space at the leading edge of the flap that directs air over the cooler, plus an open feed to the cylinder / head.
In very warm climates, it is common to remove the link and screw the end of the flap (nearest to the cylinder) to the oil cooler frame. |
| shaggy |
Nov 9 2005, 04:38 PM
what the hell is a blog?
so in warm climates it is common to remove the flaps entirely? is arizona a warm climate? even in the winter? |
| Rand |
Nov 9 2005, 04:44 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Web log.... weblog... blog. Sort of an online diary. It's a place to post notes, photos, progress, etc. Click the BLOG button at the bottom of your post and play. Remove the flaps? No... don't need to be doing that. Is Arizona warm? Does the trees moving make the wind blow? Hey Shaggy.... THANKS for posting your progess and questions. This is good stuff.... for a lot of people. Keep it up. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 13th November 2026 - 11:06 PM |
