All 2.o's fitted with sway bar?, or was this factory option? |
echocanyons |
Aug 15 2003, 11:11 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I was thinking that the 2.0's came with a sport pkg and all were delivered with swaybars and forged fuchs.
the car I just picked up is a 74 and it has utabs but no hole for the through body swaybar and is supposedly a 2.0l but the engine is displaced(like in florida sor something (IMG:style_emoticons/default/sad.gif) ) What about rear sway bars was this also a factory option or standanrd with the 2.0? Thanks |
seanery |
Aug 15 2003, 11:13 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I've had 2 factory 2.0's and neither of them had sways.
Mueller |
My old '75 2.0 had no factory swaybar or mounts on the a-arms.
My current '74 2.0 has no factory swaybar, but it does have the brackets on the a-arms. |
MarkV |
Aug 15 2003, 11:30 AM
73 2.0 came with the appearance group & F&R swaybars. 74 on everything was optional.
tryan |
Aug 15 2003, 11:33 AM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
74. got um. listed as an option. does a whole lotta good with the floor jack holding up one side. (IMG:style_emoticons/default/wink.gif)
fronkensteen1999 |
Aug 15 2003, 12:43 PM
Unregistered |
QUOTE(echocanyons @ Aug 15 2003, 09:11 AM) I was thinking that the 2.0's came with a sport pkg and all were delivered with swaybars and forged fuchs. the car I just picked up is a 74 and it has utabs but no hole for the through body swaybar and is supposedly a 2.0l but the engine is displaced(like in florida sor something (IMG:style_emoticons/default/sad.gif) ) What about rear sway bars was this also a factory option or standanrd with the 2.0? Thanks You should bookmark Dave Darling's 914 FAQ . It has a lot of excellent info about the 914. Fronken |
nebreitling |
Aug 15 2003, 12:50 PM
my 75 2.0 has a front (and rear) swaybar, i don't know if it's stock or not (it's kind of small, so i figure it's stock). oddly, however, i don't believe it came with fuchs (unless a PO replaced fuchs with rivieras (IMG:style_emoticons/default/barf.gif) , highly dubious).
JeffBowlsby |
Aug 15 2003, 12:58 PM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
All the 74 LE cars came with 'em...F+R. Stock from the factory. No extra charge.
maf914 |
Aug 15 2003, 02:00 PM
My 76 2.0 did not have sway bars, but did have front A-arm brackets for them. I added bars by a company called H&H long time ago, adjustable front and fixed rear.
Mike |
echocanyons |
Aug 15 2003, 03:36 PM
Lo-Fi Version | Time is now: 29th May 2024 - 06:36 PM |
