> 6 disc "racing" metallic clutch on the street?, no organic for 986 tran to /4 flywheel..
Mueller
post Nov 8 2005, 04:18 PM
914 Freak!
For $95, Kennedy Engineering can make a 215mm diameter 6 puck metallic clutch with the 1" X 23 spline count of the Boxster transmission.
As far as I know, no one has an organic clutch in that odd ball configuration.
Stock Boxster clutch is 240mm, not too sure if I could easily and safely turn the diameter down to 215mm.
post Nov 8 2005, 04:27 PM
Resident German
if it's anything like the racing clutch i have right now, don't do it ...
my clutch is pretty much on/off, no slip. sucks big time in commuter traffic ...
(IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy
Mueller
post Nov 8 2005, 04:31 PM
914 Freak!
QUOTE (SirAndy @ Nov 8 2005, 03:27 PM)
yea....I just did some more reading and it seems like that is not the direction to go....bummer...
Joe Ricard
post Nov 8 2005, 04:58 PM
CUMONIWANNARACEU
I don't know When I drove Jake's 914 this past summer His puck and light flywheel was different but nothin I couldn't drive smoothly.
I'm going to go that route next upgrade. 10lb flywheel lighter pressure plate and 4 or 6 puck disc.
Definately separate the men from the boys when an unsuspecting co-driver jumps in.
J P Stein
post Nov 8 2005, 05:59 PM
Irrelevant old fart
QUOTE (Joe Ricard @ Nov 8 2005, 02:58 PM)
It will also seperate your clutch linkage from its appropriate gizmos. I recommend the lightest pressure clutch that will do the job for that reason. The Kenedy stage I PP with a stock
6 spring disc works for me....and has for years of abuse.
The clutch pedal in my Mr2 is noticeably heavier than the one in the shitbox.
Mueller
post Nov 8 2005, 06:17 PM
914 Freak!
I "think" I found an OEM organic clutch that'll work if I can get away with just a slightly larger clutch OD....I'll know tonight....
Type 4 Unleashed
post Nov 8 2005, 10:44 PM
CREATIVE TYPE lV ENGINEERING
Group: Retired Members
10lb flywheel ?? I've heard that the stock fans, don't hold up with such a lite flywheel, I, was told Rimco, yusta do 10 pounders, but stoped because of the fan issue, and don't do type lV's less than 12 now?
HP motors would rev so quick, the stock fans came apart. Anyone heard anything about this?
Joe Ricard
post Nov 9 2005, 08:20 AM
CUMONIWANNARACEU
When Jake does an engine balance the fan is also part of the equation.
Yup engine spins up pretty quickly but ??? what's that got to do with blowing a fan to pieces?????
Anyway Back to the subject What did you find out Mike?
Aaron Cox
post Nov 9 2005, 10:20 AM
Professional Tinkerer
QUOTE (Joe Ricard @ Nov 9 2005, 07:20 AM)
ive seen sheered bolts from a motor that can spool too quick, using a 10lb flywheel
Joe Ricard
post Nov 9 2005, 10:29 AM
CUMONIWANNARACEU
Uh, get better bolts and torque correctly?
Brando
post Nov 9 2005, 10:31 AM
BUY MY SPARE KIDNEY!!!
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
That would not be fun.
"Why are my head temps climbing so fast??"
Aaron Cox
post Nov 9 2005, 10:43 AM
QUOTE (Joe Ricard @ Nov 9 2005, 09:29 AM)
goes without saying. not trying to be a prude...,just saying what ive seen.
your mileage may vary
Your alternator light would go on instantly (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif)
groot
post Nov 9 2005, 11:59 AM
Dis member
I run a flywheel that's less than 10 pounds on the race car "junkyard dog" engine. I've run different fans on it with questionable balance. No ill effects so far and I've put a lot of race miles on that engine this year.
- Lo-Fi Version Time is now: 15th March 2026 - 08:37 AM
